Old 12-17-2003, 11:48 AM   #1
Learic is on a distinguished road
Another PSOne Mod question. Looked but no answer!
I have already performed the PSOne LCD --> VGA mod successfully. Now I'm trying to do another mod! I have removed the screen from the original casing and I've placed it snuggly inside of a simple CD case without the plastic internal holder for the CD backing. The problem is, I had to disconnect the controller board from the screen to do this. I'm going to place the CD case with the screen inside of a slotted 1-DIN CD holder that sits below my headunit in my car. I would like to hide the controller board and everything else behind that holder out of view. At the moment, I can't find any of the translucent ribbon cable that connects the PSOne screen to the controller board. Does anyone know where I can buy a longer piece of this to extend it out further so I can finish my mod?
Learic is offline   Reply With Quote
Old 12-17-2003, 02:47 PM   #2
ProjectTwin is on a distinguished road
No idea on the ribbon cable.
Is your screen the Sony NTSC? if so can you tell me which wiring diagram you used?
Thanks,
Jason
ProjectTwin is offline   Reply With Quote
Old 12-19-2003, 08:46 AM   #3
Does anyone know of a site on the internet that talks about the Official Sony PSOne screen including the internal components? Similar to the pages regarding "The PS2 Revealed" type secenarios that show the device taken apart with all of the components shown. The reason I ask is because my original request may be misleading. I'm not sure that the component I'm wanting is considered a ribbon cable or a translucent film circuit board that connects the screen to the controller board. I just want to make or buy an extension for this cable so I can seperate the two halves and place the controller board deeper out of sight...
Old 06-26-2004, 01:10 PM   #4
Banned
rockthevolvo's Avatar
rockthevolvo is on a distinguished road
learic,
im looking for this too. ill report back to you if i find anything.
I hope the mods don't realize I can still post.
rockthevolvo is offline   Reply With Quote
Old 06-26-2004, 01:31 PM   #5
no1knows's Avatar
no1knows is on a distinguished road
solder on yr own ribbon cable after chopping it in two... as for extending the ivnerter, not a good idea, the further away the ivnerter the dimmer the backlight.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 06-27-2004, 02:02 AM   #6
starfox's Avatar
starfox
those flat cables tend to be for short runs only, you'll probably run into signal integrity problems if you run that sort of cable for a long distance.. you'll probably have to solder in some cable yourself.
starfox is offline   Reply With Quote
Sony PSone LCD VGA mod wiring ProjectTwin LCD/Display 14 12-23-2003 09:11 PM
Please answer question on headrest displays Rafster LCD/Display 0 10-09-2003 08:21 PM
Probability Question.. please answer if you are mathematically great... :) THEMP3KID Off Topic 27 09-24-2002 12:12 PM
quick lcd question! anyone whos done one knows the answer! minnow255 General Hardware Discussion 2 09-12-2000 05:31 AM
