The MP3car.com Store
Thread Tools Display Modes
Old 12-22-2003, 07:52 AM   #1
My Photos: (0)
Unhappy TM-710VGT & Jurrasic Park Image....digitalww...lilliput
Hey
I just received my TM-710VGT display from DigitalWW and it is having alot of Jurrasic Park and other "over range" issues. About 60% of the time I cannot get into the bios without the Jurrasic Park image appearing then fading to white. Everytime I boot the computer the image appears...fades to white then proceeds to the windows boot. In Windows...I have not sucessfully set the display to 1024 x 768..nor have I been able to set the refresh rate to anything above 60 Hz.
Does anyone know if there is update to the display's firmware that will help correct these issues? I have found nothing on Lilliput's site nor digitalww's.
Shane
Sick-B0y is offline   Reply With Quote
Sponsored Links
Old 12-22-2003, 08:29 AM   #2
bertybassett's CarPC Specs
bertybassett's Avatar
Vehicle: VW Beetle (lhd)
My Photos: (0)
no fixes as today with that problem.
bertybassett is offline   Reply With Quote
Old 12-22-2003, 09:46 AM   #3
Mr. Wiggles
shakes's Avatar
Vehicle: 2001 Jeep Cherokee Limited
My Photos: (0)
i have the same screen from digitalww ... i've found that if the LCD is already powered on, THEN the pc is powered on ... there's a good chance of the 'fade to white' issue. However if i power the PC on, then turn the LCD on, it always works fine.
I've had no problems other than that.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 12-22-2003, 11:01 AM   #4
My Photos: (0)
Thanks Shakes...I'll give that a try tonight and see if I get any better results
Old 12-22-2003, 11:39 AM   #5
leenas's Avatar
My Photos: (0)
I had that problem with fading to white (kinda of scratchy white that just looked bad). It started happening more and more frequently until it go to the point where i would turn it on and off 20 times or so and it would finally be ok and then after 5 minutes it would fade to white.
I got him to replace hte screen for me since then its been fine but it just happened once about a week ago but been fine since then.
Hope that helps. I would talk to him and tell him the problem.
Also my screen is the kind that is manually pulled out from the dash.
leenas is offline   Reply With Quote
Old 12-22-2003, 01:16 PM   #6
My Photos: (0)
bump
Sponsored Links
vB code is On
Trackbacks are Off
lilliput problem-no image. sham LCD/Display 5 01-14-2004 12:13 PM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
