Thanks for the feed back STIdev.
Mike,
Even the brightest LCD will not give good results when viewed at an angle in direct sunlight, its just the nature of LCDs. Mine is located in a position that gives me a good viewing angle, this is important.
I have never noticed a reduction in brightness when it is cold, but its the middle of summer here so it hasnt really been that cold, it was 37 degrees C on Christmas day at my place so I cant give much info about cold weather performance, but it seems to handle the heat fine.
Good luck
Robiewp,
Quote: Originally Posted by robiewp
patrol, I'd be interested in hearing more specifics about your battery monitor. Any writeup for it that imissed?
Hi Robie,
I use the patrol for some serious 4 wheel driving around Australia into some very remote areas so monitoring the condition of my batteries is very important. I run camping lights and a fridge off the aux battery. Charging of the aux battery is managed by a Rotronics dual battery system. This prevents the main battery from discharging completely.
The monitor is based on a kit sold by a local electronics company called Jaycar Electronics (
www.jaycar.com.au) the part number is KA1683. I used two of these kits (one for each battery) and squeezed them into a small box. The monitor simply gives a voltage reading between 11 and 14.5 volts.
The kit is very simple and based around a LM3914 chip. Having both displays together allows me to see when the Rotronics system has switched the AUX battery on to charge, ie if both displyas are at about 14 volts when the engine is running then both batteries are charging. The rotronics system wont allow the AUX battery to charge if it is not happy with the condition of the main battery so if both are charging all is good.
This type of battery management is pretty important when travelling in remote areas.
Hope this help, I can send a schemaitc of the battery monitor if required.
Cheers
