Quote: Originally Posted by Brancon
Hey, Truckin...I thought of gettin the same LCD...how do you like it? Is it bright enough?
It is bright as all H3LL.... I have the contrast and brightness turned down to 30%....
It would burn your retnas out if you stared at it with factory settings.
I have not had the time to cut the connector... so it has only been temp installed for one road trip (with an inverter). I am still considering how to mount it and what solution to use for a case.
Cheers
