Old 12-31-2003, 03:03 PM   #1
PC powered Xenarc Screen..
Hey folks. Need some help.
I've done all the reading and the research to know how its done, but something isnt working. I've purchased a few 2 position molex adapters to make all my connections. I know the screen works because when I reconnect it to the transformer it came with then it shows the "Portable Display" title and it works with the PC properly.
When I connect it via the PC power supply the led at the bottom of the screen lights up but it doesnt display anything. I'm using the red(+12) and black(-12) from a molex connector of the power supply. From there it runs into a 2 position molex thats connected with the facory pin connector.
The main is issue is that since I'll be powering this from the PC in the trunk I'll need a cable long enough to reach the trunk. So I'm testing it with a 15ft cable. I have not tested it with a multimeter yet so I dont know if power is dropping towards the LCD screen.
Any suggestions or corrections would be appreciated.
Oh and Happy New Year =)
Zadilla is offline   Reply With Quote
Old 12-31-2003, 03:06 PM   #2
kuo
kuo's Avatar
is it possible the red it the 5v and the yellow is the 12v?
kuo is offline   Reply With Quote
Old 12-31-2003, 03:42 PM   #3
Sounds about right, might want to try that...
2003 Audi A4 1.8t (Totaled, Project Canceled)
dummptyhummpty is offline   Reply With Quote
Old 12-31-2003, 03:57 PM   #4
Phat Boy
Pudge's Avatar
KUO is right
Pudge is offline   Reply With Quote
Old 12-31-2003, 04:35 PM   #5
none's Avatar
You should always check things with a multimeter before hooking up your toys. If this were a 5 volt piece and you hooked it up to the yellow wire, you would have an expensive doorstop right now. Take it from someone who has been there - the magic blue smoke comes out.
Yellow is 12 volt.
none is offline   Reply With Quote
Old 12-31-2003, 05:08 PM   #6
LESLIEx317537's Avatar
Yellow and sometimes Orange.
I leanred this while making fan buses for fans. You can run fans at 5 volts to save amp/watt draw. Good for carpcs that need to save power.
Also if you take the 12 volt and ground it witht he 5 volts line you can get 7 volts. But I don't like that method.
LESLIEx317537 is offline   Reply With Quote
Old 01-01-2004, 04:35 AM   #7
Allow me to wipe the egg from my face.. I thought this might have been the problem but I was certain the red was the 12v. Thanks for clearing this up for me guys.
Old 01-01-2004, 08:07 AM   #8
I learned something new today.
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
wiring up a pc vga out to tft laptop screen Kenny LCD/Display 5 04-23-2003 08:54 PM
FV24 and Xenarc wide screen driver How to cproaudio LCD/Display 3 03-15-2003 01:16 PM
xenarc screen the_spy_guy LCD/Display 0 11-15-2002 11:58 PM
FS: Xenarc 7" VGA touch screen rdliou Classified Archive 1 09-27-2002 09:44 AM
Car Environment Temperature vs LCD screen, PC?? dekodan General Hardware Discussion 4 08-01-2001 03:46 PM
