Old 01-01-2004, 05:38 PM   #1
Glare reducing material over Lilliput touchscreen?/
I continue to fight the glare/reflection on my Lilliput touchscreen. Does anyone know of some sort of glare-reducing flexible plastic material I could put on top of the touchscreen. Obviously, it needs to be low-loss (let most of the light thru), and very flexible so that it doesn't mess up the touchscreen performance. I'm not sure if such a thing exists, but if we have any plastics experts out there, your comments would be welcome.
MikeH
MikeH is offline   Reply With Quote
Old 01-01-2004, 08:41 PM   #2
I know 3M makes film designed for this purpose - check this link . Problem is whether they sell the stuff to end-users. Please let us know if they do - I have the same glare problem on my Lilliput.
shchua is offline   Reply With Quote
Old 01-02-2004, 09:49 AM   #3
DodgeCummins's Avatar
This is probably not what you want, but Walmart has this LimoDark stuff, for temporarily sticking to your window. I used to stick it on my display at night to cut the glare (my old dstn display)
current projects
DodgeCummins is offline   Reply With Quote
Old 01-02-2004, 09:52 AM   #4
Dodge,
Thanks for the lead. Did you use it to cut glare, or to reduce the brightness of your screen at nite? My glare problem is during the day.
Schua,
I looked at the 3M stuff. Very expensive and I can't find a retail outlet for it. I'm experimenting with some stick-on celophane-type material right now. I'll let you know how it goes.
MikeH
Old 01-02-2004, 10:27 AM   #5
mike,
check this out.
http://www.tigerdirect.com/applicati...3001&CatId=165
I don't know if this is exactly what you wanted, but you could cut the sheet down to the size of screen.
suprthug8d is offline   Reply With Quote
Old 01-02-2004, 11:20 AM   #6
SjLucky's Avatar
I allways hated those damn things
I have a great idea for glare
tint your windows... it blocks all UV rays knocks out alot of the heat and some other jazz
"You anit leading but two things Jack and **** and Jack left town"
"Just When You Think You Forget About a Chick She Pops Up Like a Case of Herpes Simplex B"
Ask Me About Hubernate!
SjLucky is offline   Reply With Quote
Old 01-02-2004, 11:51 AM   #7
SjLucky --- good idea. I think I'll look into this type of product. However, my guess it they are too stiff to let me use the touchscreen.
Superthug - most of my glare comes in thru the front windshield. Don't think I want to tint that.......
MikeH
Old 01-02-2004, 11:53 AM   #8
Custommx3's Avatar
plus u can still use a touchscreen
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 01-02-2004, 12:04 PM   #9
RX7FDTT's Avatar
Maybe think about a polarising filter under the touchscreen, so that the touchscreen isn't affected by the glass....
RX7FDTT is offline   Reply With Quote
Old 01-02-2004, 12:12 PM   #10
Maybe a lame idea...
How about trying a piece of window tint film over the screen?
Daz155HGT
Daz155HGT is offline   Reply With Quote
Old 01-02-2004, 01:02 PM   #11
RX7....great idea, I've just been reluctant to pull apart my Lilly. But I may get desperate enough to do it.
Daz....I think the window tint stuff would only darken the image not reduce glare....not sure tho. May look into it.
MikeH
Old 01-02-2004, 03:30 PM   #12
NJay's Avatar
The problem is that its the touchscreen membrane that is causing the glare. The screen itself doens't refect as much so putting the film between it and the touchscreen won't work very well.
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 01-02-2004, 03:46 PM   #13
SjLucky's Avatar
I got the greatest idea of all time
move your lcd so it doesnt get any glare...
my brillance is stunning isnt it
Old 01-02-2004, 04:06 PM   #14
NJ....ooooo, you're absolutely right!
I went to Office Depot and bought a "vertiable plethora" of various plastic sheet material (various colors, frosting, most for report binders). I chopped each of them into 155mm x 92mm pieces and mounted them on top of my touchscreen. Result: nothing worked very well. The were all too thick. They did a great job of getting rid of the glare, but they also got rid of about 50% of the image brightness. They also caused the image to be fuzzy, or frosted looking. I even tried a Belkin screen protector for the iPaq. It caused as much glare as the Lilly.
One of the better ones from the group was the Wilson Jones transparent dividers. It's still marginal, but the clear/white sheet from this pack helps.
Here are a cople of shots. Unfortunately, it's overcast here today so the glare is usually much worse. But this will give you and idea.
MikeH
Old 01-02-2004, 10:41 PM   #15
Njay is right. The touchscreen membrane is the culprit. What we need is a to put a circularly polarized film on TOP of the touchscreen membrane (with the same optical qualities as those used in 3M anti-glare film) but they're almost impossible to get off-the-shelf. I don't think automotive window tint film will work but its worth a try.
Lilliput touchscreen prevents standby Alric LCD/Display 21 03-18-2004 03:04 PM
How Can I Prevent uninstall/reinstall of Lilliput Touchscreen drivers rgardjr Input Devices 1 01-08-2004 07:59 AM
Lilliput touchscreen drivers HELP PLEASE CDesigns LCD/Display 1 11-24-2003 04:42 PM
Lilliput Touchscreen From carTFT.com blicky_1 LCD/Display 14 11-08-2003 05:56 PM
speaker next to lilliput touchscreen. clever? sham LCD/Display 0 11-02-2003 05:47 PM
