01-05-2004, 07:34 PM
#1
How can i get 800x480 on my laptop vga output?
hi, i have been stuck all days messing with powerstrip to get the naive 800x480 resolution for my monitor. i have a gateway solo 3450 laptop with the s3 savage ix graphic card video chip.
under powerstrip, the customize resolution option is blurred out, so i'm thinking that my graphic card does not support customization of resolution?
i tried creating a monitor driver file with the 800x480 resolution and updated my monitor with that driver, but it still does not give the option to select the 800x480 resolution.
would somebody please help?
Reason: clearify title
01-06-2004, 03:53 AM
#2
i agree
01-06-2004, 05:24 AM
#3
Are you just using the external monitor or are you using both? I have had problems when both screens were active. Videos couldn't be displayed on more than one screen, mediaplayer just showed a black frame on one of them.
Otherwise you just might be out of luck. Powerstrip doesn't support all graphics card.
01-06-2004, 12:02 PM
#4
My sony notebook using ATI video and I need to set the primary monitor as the external monitor. Then you can see video on the external monitor.
I hope it would help
01-06-2004, 12:56 PM
#5
yourbig
I have the same problem with my EPIA M10000 using the onboard video. It appears that this (my) hardware cannot support custom resolutions. Perhaps you're in the same boat.
MikeH
01-06-2004, 01:14 PM
#6
Thanks noname, i figured that out myself.  Just wanted to know if he ran dual monitors since that could be a problem for powerstrip to handle since they are on the same graphics card.
01-06-2004, 02:22 PM
#7
from all indication is that i'm so out of luck. s3 graphic card dont support customize resolution. i cant set my external vga as primary display.
so now im back to step one. build a mini-itx box, or get another laptop that supports 800x480 with powerstrip.
my car is such a mess now. i'm driving everywhere with all my dash board out in the seats.  (
this is really a painful lesson.
01-06-2004, 06:40 PM
#8
You absolutely have to have 800x480??? I run 800x600. I can't set up my external monitor as primary either, nor do I need to. It works fine just as if your laptop was docked. Close the lid and the laptop screen turns off, and the external output is on. ??
2002 Nissan Altima 3.5 5 Speed Bose FM/6CD ED E12A P4 2.26 512 Ram Ti4600 CDRW DVD Lilliput 200mW 802.11b Trackman AutoTap GPS Opus 150 Carnetix 1260
2005 Nissan Titan SE Dell GX-150 P3 1.0 512 Ram 20G GF4 MX4000 USB 2.0 DVD/RW Xenarc GPS Trackman
01-06-2004, 06:43 PM
#9
Isnt 800x600 a little distorted on a 16:9 screen?
01-07-2004, 12:08 AM
#10
running the naive resolution of the lcd will always give you the best display quality. mine is running at 640x480 now, and it seems okay. but i will need to find a way to get a 800x480 signal to feed it some how.
it does seem like many laptop suport customization resolution. the wide screen laptop are too expensive. i hate to build a box because of the power supply issues.
01-07-2004, 12:34 AM
#11
Not noticeably.
01-07-2004, 12:36 AM
#12
Not noticeably.
Well it wasn't until you pointed it out!
01-07-2004, 12:55 AM
#13
I'm sorry, and you are....?
Talking to yourself again Altimat ?
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
01-07-2004, 01:04 AM
#14
Yup going a little crazy with IRQL not less than or equal BSODs - maybe I should sleep....
01-07-2004, 01:09 AM
#15
DON'T EVER SAY THOSE WORDS AROUND ME AGAIN !
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
| Thread Tools |
| Display Modes |
Linear Mode
