Quote: Originally Posted by gtd86
so just connect the 2 wire from the car cigarette adapter to the +12 and -12 output to the motherboard power supply cable? as in connect the 2 wire to 2 of the wires on the atx block(20 wires), or do i wire it to the opus some other way?
No, you can power the Lilliput monitor directly from the Opus's regulated +12V output without going through the car cigarette adapter. Here's what I did - run two wires (18 AWG) from the Lilliput to the Opus. At the monitor end of the wire, solder a barrel plug (get the correct size) that fits into the monitor's DC in jack. At the Opus end, I soldered the wires into a Y power splitter (+ve to yellow and -ve to black) - the one that has a female connector that plugs into the Opus 4-pin power connector for hard disks and splits into 4-pin hard disk power connectors. This way you can disconnect the wire if you need to bring the PC into the house.
The tricky part is getting the polarity right. Measure the voltage at the barrel plug BEFORE plugging it into the Lilliput. The center connector should be +ve and the outer connector should be -ve.
