Old 01-23-2004, 10:49 AM   #1
bonzo206 is on a distinguished road
recognizing Thrustmaster PSOne
Hi PSOne Modders,
Iīm glad to have my Thrustmaster PSOne Screen connected to my PC with a reasonable picture. Iīve tested all the different modīs, but only MPROīs one has worked (in NTSC-Mode, the Screen is switcheable). Now my next problem is to get it recognized by the graphics card. Iīve tested it with three different cards:
ATI Radeon 7500
ATI 9800SE AIW
Matrox Mystique 220 PCI
I have connected PINs 4+11 (VGA) to PIN 8 (Thrustmaster), but that didnīt work. Has anybody connected his Thrustmaster Screen to one of the cards above and if yes, how ? ? ?
Thankīs a lot upfront for your support
Bonzo
bonzo206 is offline   Reply With Quote
Old 01-23-2004, 04:06 PM   #2
MTWallet is on a distinguished road
Clarification Please...
Do you mean recognized as a secondary display? I have the official Sony LCD, and haven't had a problem with the display coming on as a single display with a Matrox Mystique (not sure which model) had problems with clarity on the display though. If secondary card, have you tried putting +5 into the LCD from the video card?
Quote: Originally Posted by bonzo206
Hi PSOne Modders,
ATI Radeon 7500
ATI 9800SE AIW
Bonzo
MTWallet is offline   Reply With Quote
Old 01-24-2004, 04:18 AM   #3
If I connect the Thrustmaster to the AIW or 7500 as secondary, I see a picture on the screen, but the configuration of the card (properties/enhanced/view), where I could setup the different connections (VGA, TV, DVI) says, that no monitor is connected and therefore I couldnīt set up a different resolution to the display.
I hope this describes my problem a little more
Thankīs again for your help
Bonzo
Old 01-27-2004, 10:10 AM   #4
Sorry I'm not gonna be much help on this one. I haven't set mine up as a secondary. I've been setting it up as a single display on a Matrox G200 (originally used a Matrox Mystique but I think there was a problem with that card because it worked but there was some kind of horizontal scan freq. problem that made the image not clear). To work with LCD as an only monitor w/o worring about losing the whole shooting match if it went out of sync, I've been viewing the computer it is on throught XP Pro's remote desktop control on my main computer. Regarding the LCD as a secondary I think FoxPro was saying that he had to hook up a regular monitor for the card to detect, and then switch it with the LCD. I've had no problem using the LCD as a primary though. Everything up until powerstrip loads is squirrly looking but I understand there is a BIOS mod I can do on the Matrox G200 that will put it in a permanant 15Hz setup, so I should be able to see MB BIOS settings etc with the LCD. Best of luck to you!
Bonzo
Old 10-24-2004, 11:12 AM   #5
Wrath- is on a distinguished road
Cool
Did you get it to work with the ATI Radeon 9800??
I have same problem. but i only have one card so i cant realy test it. im stil unsure if it is connectet the right way. So im planning on building the conposite converter and then use it in that way.
or buy me a sony display
but it would be vary nice if anyone could give some support on the thrustmaster display.
Wrath- is offline   Reply With Quote
Old 10-24-2004, 11:32 AM   #6
Raw Wave
Ricky327
Before you build the composite converter download powerstip first and see if the card supports it.
My Radeon on the compaq evo n1000v support composite so I guess your one should as well.
Ricky327 is offline   Reply With Quote
Old 10-24-2004, 02:04 PM   #7
It has s-video out. so it should work??
my card is a Shappire radeon 9800 pro 128mb ram with the old r350 chip
Old 10-24-2004, 02:13 PM   #8
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
I use an Nvidia Geforce4 MX440 and mine works just fine.
I am confused by your post a little though...
You say you're happy that you have it working with the PC, then you say you can't get the graphics card to recognize it. What exactly is going on here?
You should install Powerstrip and try it. I think what you're saying is your PC doesn't see your LCD connected to your secondary vid, so you can't change the resolution. Is that correct? If so, what were you using to change the resolution/timings anyway?
Powerstrip is probably the answer.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 10-24-2004, 02:14 PM   #9
Tidder's Avatar
As far as your problem wrath, I think I've seen something about video card not detecting a display plugged in, so it doesn't send video signal. Do a search on it...
I'll search a little too.
Tidder
Try RevFE
Best Quote EVER!!
Old 10-24-2004, 02:19 PM   #10
I have tested my card and i can run 2 monitors on one card but cant get the freeking display to work at all. If it works at all i dont know.
Ill redo my wires later this evning and se if it works. else im buying the parts fr the convertor tomorrow and see if that helps me.
btw. what settings should i run in powerstrip if i run the display from tv-out?
Old 10-24-2004, 02:21 PM   #11
Hacked PSOne LCD w/Touchscreen ??? wtf ??
dont even own a car
Old 10-24-2004, 04:58 PM   #12
Tidder's Avatar
If you're using the tv-out to get the signal to your PSone screen, you don't need any powerstrip settings at all. You can just use windows. Powerstrip is just for the special timings with the VGA hack.
What's so wtf about that?
Tidder
Try RevFE
Best Quote EVER!!
Old 10-24-2004, 07:45 PM   #13
you have 2 screens ? "w/Touchscreen" or is your psone lcd realy with touch ??
Old 10-24-2004, 07:48 PM   #14
But to use the s-video out for my thrustmaster i need that converter? or can i just hook it up.
Damn i hope i havent burned my lcd of in any ways
i have rewired it about 10 times and tryed to swith around pin 1 and 12.
Old 10-24-2004, 07:54 PM   #15
Tidder's Avatar
PSone screen is really touchscreen. Bought an overlay from digitalww.
You'll probably need an S-video to rca adapter to hook up your screen to your card.
Does the thrustmaster have composite input, or are you gonna have to solder something?
Tidder
Try RevFE
Best Quote EVER!!
Thrustmaster PSOne Screen - help !!! bonzo206 LCD/Display 2 01-11-2004 02:10 PM
PSOne Screen and Video MatrixPC LCD/Display 0 12-24-2003 11:24 AM
Thrustmaster PSOne LCD Screen Removing Backlight Daninino LCD/Display 0 08-06-2003 04:37 AM
FOR Sale= Black PSONE LCD jsm49ers Classified Archive 1 01-05-2003 02:04 AM
PSone LCD help needed jsm49ers LCD/Display 3 11-10-2002 10:20 PM
