Old 09-05-2005, 02:17 AM   #16
http://www.mp3car.com/vbulletin/lcd-display/58644-elo-touch-overlays-10-5-reuseable.html
You might want to try and contact AWDNUT factory connectors? Not sure what he can or can not get, but worth a try if you need something.
Silentbob343 is offline   Reply With Quote
Old 09-01-2006, 12:36 AM   #17
Did you finished your project? How does it look?
Good work on the SVGA Pinout btw....
I plan to completely redo my dash and center console of my 67 Tbird. So while at it, I could add the 12.1".
I got a 4820 for free with a DFP-to-DVI-I Cable but I had to change a neon inside (took one out of an old 486 laptop display module) and it works perfect now. But I dont know how to make TouchScreen works.
I have the RS485 connector and know the pin configuration, but dont know what to do to with pin 2 and 3.
Pin 1 = 5vdc (for USB)
Pin 2-3 = 2x Data I/O
Pin 4-5 = GND
Pin 6 = 12vdc. (LCD Power Input)
How did you manage to plug the Touch screen?
Did you have to buy/build a converter for it?
Did you plugged USB or Serial?
Sly1990 is offline   Reply With Quote
Old 09-01-2006, 04:34 AM   #18
lez
lez's Avatar
Its serial rs232, noconverter, pins 2/3 to pins 2/3 on the pc 9 pin, oh and a ground from pin 5.
I have removed mine etc as just changed vehicles, I wont be fitting it back in, its too large for a european car/dash.
Max I think I could do would be a 10.2 / 10.4, but will probably buy an 8, when I can afford it.
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
lez is offline   Reply With Quote
Old 09-03-2006, 11:22 PM   #19
I tried what you said but I wasnt able to make it detect.
After 1 day trying on a PC with only a HD and a Video Card, I decided to try by USB instead.
I made a cable and used TouchWare SR6 5.xx USB Drivers.
Guess what? Works the 1st time, it detected my Screen, my TouchScreen Module and the monitor internal USB hub. (Happy Me!!!)
Everything works perfect now.
I wish I could put hands on 1 or 2 more freebie like these.
They look to be made to last like every IBM stuff.
They never were the fastest machine, but they alway were the toughest.
Old 09-04-2006, 06:38 AM   #20
lez
lez's Avatar
If it connected by USB then its NOT a 4820-4ft, a 4ft is serial only, so the wiring posted above is not for you! Please add your connections etc to this thread to help others!
What model is it you have? I guess it is a 4820 but which revision
/model
Lez.
Old 09-04-2006, 01:52 PM   #21
I didnt tried a VGA DB15 conversion yet. I'm unsure if it will be possible since the IBM Manual says it uses DVI-D Video.
I've ran it on an old IBM 4MB Office desktop Videocard (DVI Connection Only) or on my actual VideoCard (MSI FX5900XT) with the DFP-to-DVI cable I got with the monitor..
The exact model is 4820-48T. (Capacitive - USB hub - DVI Color)
Connection Pinout for the USB/TouchScreen
IBM RS485 --- USB Port
Pin 1 --------- Pin 1 (Red +5V)
Pin 2 --------- Pin 2 (White D-)
Pin 3 --------- Pin 3 (Green D+)
Pin 4 --------- Pin 4 (Black GND)
Optionnal Power source input (RS485)
Pin 5 - GND
Pin 6 - 12VDC 2A
*Usefull when doing a permanent install
Old 11-26-2006, 02:47 PM   #22
Quote: Originally Posted by lez View Post
Just worked out the pinouts and posted them on the uk site, you can find them their.
Lez - I'm about to purchase at 4820-4FT 12.1" monitor and you seem to be the world's leading expert on getting one of these things connected to a computer. I've read your posts and done a bunch of similar research to you but still have a few questions.
First, you reference the pinout that you posted to the UK site... which uk site? Do you have the web address? Also, you mentioned that you weren't going to be installing your touch screen into your new car - any interest in selling the cables and power brick that you have?
Finally, the reason for the 8 pin RS232 connector (which I'm sure you know now) is to support the magnetic strip reader and the touch screen at the same time.
Please get back to me - I very much appreciate any help you can provide.
Thanks!!
Gavin
gmctavish is offline   Reply With Quote
Old 11-26-2006, 03:21 PM   #23
lez
lez's Avatar
Hi.
Yeah I noticed the magstripe adaption, I take it you have the same dumb silly connector for serial as I have........
http://www.digital-car.co.uk/forum/s...ead.php?t=4584
Lez.
Old 11-26-2006, 03:28 PM   #24
I do have the same rediculous serial port connection. I am baffled by IBM's decision to have the connections be completely proprietary. I've found a company selling the video cable, but I haven't been able to reach them to determine what that will cost me. I haven't been able to find anyone selling the serial cable yet - but I'm still looking.
I'm very excited to get this monitor up and running - but from your posts - its going to be a pain.
You're not, by any chance, looking to sell your cables are you?
Any other tips or advice before I embark on this construction project?
Old 11-26-2006, 04:10 PM   #25
lez
lez's Avatar
I did not get any cables, I built some, its really easy to build cables, finding out where the wires go is always the problem, and thanks to me(!) thats been done, its on the web site.
Dont bother trying to buy plugs for monitor end, just buy a 9 pin and solder 3 wires from it (about 30cm in lenght) to the screen, do the same with a 15pin for the vga, pass them through a hole in the case back, then you can connect these 'pigtails' to a standard set of cables.
Lez.
Old 11-26-2006, 04:11 PM   #26
and believe me - I'm happy for your post!
I'm going to purchase this monitor then and go get the connectors this week - I'll let you know how it goes. Thanks for your help so far.
Old 11-26-2006, 04:40 PM   #27
lez
lez's Avatar
Anyhelp I can give I will, still little busy at the moment with life and also my other projects, which are currently stalled as I'm having PCB issues, cant get toner transfer method to work too well, so resurrected and also bought a plotter (ebay!), spent last 3 days trying to build a good working pen to draw the etch resists, all just seems to come off when etching. been a bad week really, lots of wasted boards.
Lez.
Old 12-30-2006, 06:45 PM   #28
Talking 4820-4ft pinout
Regarding the pinouts on the 4820 end, how are you numbering the connections? I'm sorry if this is a dumb question, but I had to look up the pinout diagrams for the serial cable and VGA standard. I'm not great with electronics but I've been soldering kits and car audio for 3 years now, just havn't worked with making custom cables. ANY help would be greatly appreciated
Rayman411 is offline   Reply With Quote
Old 01-17-2007, 02:35 PM   #29
Lez,
I would like to attempt this project as the 4820-4ft's are pretty cheap. I am going to use mine as a controller of a HTPC. Am I understanding that you are soldering your cables directly to the 4820? I would prefer to just connect a few different serial/vga cables together to form a detachable cable if needed. If I am wrong about this assumption I am sorry. Are you only using 1 VGA(15pin) and 1 serial(9pin) to complete this, or are there extra connectors needed? I can figure out the pin configuration but I dont understand since there are 2 cables (video, touchscreen) coming from the 4820 and there should be two goign to the pc correct?
jaspr180 is offline   Reply With Quote
Old 01-22-2007, 07:09 AM   #30
lez
lez's Avatar
Quote: Originally Posted by jaspr180 View Post
Lez,
I had 2 sockets on the 4820 to connect to the two sockets on the pc, in an ideal world I would need 4 plugs and pieces of cable.
however, not being an ideal world, I could only find 2 plugs, for the pc, I could not find a supplier local to me for the 2 plugs to fit the 4820, so I just soldered the cables into the 4820.
I would have liked to have done it in a more professional manner, but I had no plugs.
cable pinout above, oh hang on its not above is it, is on the 'other site' from the uk, any how cable pin out is done, it took me /ages/ to get the wiring sorted for the serial side of the TS.
Lez.
Where to find a touch screen overlay? bayere LCD/Display 3 01-13-2004 12:32 AM
buying touch screen for a car liorw Input Devices 2 07-31-2003 07:00 PM
UPDATE ON: TM-701L and Touch Screen Kit digitalww LCD/Display 65 07-12-2003 12:39 AM
FS : 12 Inch Touch Screen / 25 Foot Cable ezfilez Classified Archive 2 04-16-2003 03:08 PM
I have no touch screen... how do u make an interface? domdino General Hardware Discussion 1 10-07-2002 09:39 AM
