Quote: Originally Posted by digitalww
Is the touch screen USB? Can you take a picture of the way your touch screen controller is connected to the controller board? The white connector on the touch controller has 5 pins but the little wire cable has 4. They need to be connected in a certain way. Other wise it will do what you're describing. Also another way to test the VGA board is to unplug everything from the controller (VGA) and connect it to 12V. The LED should come one and in a few seconds it will start blinking (stand by mode). If it does that then it should be OK.
This could also be a more serious problem. I have new controllers but they are not cheap.
Armen
I didn't change ANYTHING as far as connections go. The video input connector may have come loose.
Armen, the screen does what you said. It'll go into sleep mode just like it's got video on the board. If I hit the source button, it'll stay solid and then go to sleep mode again. If I unplug the touchscreen controller from the main board, what will happen?
I'll try to take pictures later.
