Quote: Originally Posted by superman19
so does anyone know how to test each component individually? also, can someone tell me what the inverter does? thanks.
I'm not sure that you can do this unless you have 2 units - you can then swop components around to see which one is bad. My suggestion is to test the screen without the touch panel. Lay out all the components (LCD panel, controller board, inverter) on a flat non-conductive surface, making sure none of the components are touching each other. It may a bit hard to do with all the interconnecting cables connected but if there's a need to place one component under another because of cable length, make sure you insulate them with a piece of cardboard or something similar. Double check all flex cable connections and ensure that the flex cable is seated firmly in the connector. My Lilliput refused to power up when the flex cable from the controller board to the front panel board was not inserted fully into the connector. Good luck !
The inverter in the screen takes low voltage DC (12V usually) and converts it into the high voltage needed by the backlight (usually a cold cathode flourescent lamp). Keep your fingers away from the inverter when it is operating. The output can give you a nasty shock if you are not careful.
