Old 02-05-2004, 01:22 PM   #1
tolisn's Avatar
Lilliput info required
Does anyone know if the LCD of a lilliput TFT monitor can be mounted at a distance from the electronics circuit board. I want to mount the LCD on my center console and the electronics near the PC due to the lack of space on my center console.
Thanks in advance
tolisn is offline   Reply With Quote
Old 02-05-2004, 01:47 PM   #2
Hacksaw's Avatar
The biggest problem I can see is the flat foil cable that goes from the control PCB to the display - I've started looking for a longer replacement for my switch PCB but haven't found one yet. I've opted for a length of standard 3m ribbon cable as it is just button inputs in my case, but for distancing the display from the PCB...
The other connections are simple stranded wires so they can be extended easily.
I'm not sure how it will behave with a long cable though, logically it should be the same, but stranger things have happened...
2000 Vauxhall Vectra SXi
EPIA M12000 / 256MB RAM
PW-120 + ITPS
Slot Loading CDRW/DVD
30GB 2.5in HD
Lilliput 7" VGA + Touchscreen
GPS Nav
Installation progress {+++++++} (Installed! :) )
Hacksaw is offline   Reply With Quote
Lilliput install in and Impreza, Lilliput issues SubPuter LCD/Display 76 04-19-2004 09:56 PM
Lilliput +12v PSU...how can it work? MikeH Power Supplies 2 01-09-2004 10:31 AM
lilliput video In sensitivity?? spankmebumbum LCD/Display 0 12-27-2003 05:25 PM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
Lilliput 7" TFT Car Monitor w/audio and Touch Screen foneman LCD/Display 3 09-23-2003 10:46 AM
