Ok Now let see if the controller senses when you touch the panel.
Controller is mounted inside the housing, on the back panel. If look through the front of the housing towards the left side of the back panel you should see the controller. Now with the USB cable plugged in touch panel and look at the controller. You should see an LED light up every time you touch.
Is the LED lighting up?
Quote: Originally Posted by IIJasonII
yes it does detect the controller, it looks like that
