first off, theres TFT and STN (someone already said that). STN is something to watch out for, but the for the most part i dont see it much anymore.
you can get that 7.2" LCD (and i prettymuch garuntee you that its a TFT as well). but there no free lunch. input on that monitor will be composite video only (the kind your VCR/TV uses). while this is great for watching movies on, when you get into a carpc application it most likely wont cut it. unless you make your text REALLY REALLY BIG, its going to be fuzzy, and hard to read. in addition, you will need a video card that has composite video out.
sadly enough, the only real option for a carpc that is READABLE is TFT/LCD monitor with VGA input. that will input directly from your computer, without conversion, and offers FOUR TIMES the resolution of standard composite monitor! unfortunately, it also costs around $300 for the monitor instead of $100.
long and short of it: if extreme fuzzyness works in your setup, have at it. if you need a clear picture however, your gonna have to save up a bit more and spring for the more expensive one. all the ones currently on ebay right now start at $300 and have built-in touchscreen. from time to time you can catch a model without the touchccreen for a tad less.
Good luck!
