Old 02-18-2004, 02:35 AM   #16
How do you separate the wires spyhunter? Its a bit risky no? How do I tell where I can cut and where I cant? I been to the WRX site but firstly the connector is laying on the side, while mine is standing up. Well that's no big deal but is there a way to check if pin 1 on the guide is the same side as mine? I guess that's when I need to take measurements with the multimeter eh?
From the WRX site, I should cut on the white or the blue of the ribbon? And to short them out, gotta use a solder? isnt that a permanent solution? =) btw, those wires easy to solder? Because most wires i've come cross wont stick on the solder and I dont know why.
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 02-18-2004, 12:16 PM   #17
If anyone wants to part with there lilliput front bezel or even the back would help me, please pm me, i am thinking of doing a install in my dash and need an experiment bezel.
THanks.
pogue1000 is offline   Reply With Quote
Old 02-18-2004, 09:11 PM   #18
spyhunter's Avatar
Masch i took a small knife and carefull seperated the individual wires from the ribbon. the blue part i just removed, its like a sticker. the wires themselves carry such a small current that risk of frying the whole thing is nil. use a multimeter to double check the connections and reference the stuff from the pictures. I had to rewire mine after i got it back together after i realized that i references from the wrong side.
from there i just directly solder the (my wires) to the ribbon wires. its the pain in the *** getting a decent joint. thats part of the reason for the disclaimer and comments in the original post.
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
spyhunter is offline   Reply With Quote
Old 02-18-2004, 09:58 PM   #19
HI,
A little off topic... I need the housing for the DWW-7VGA...
If anyone has no need or wants to part with it please let me know
Tnx
ALIBABA - I30 99
Nemiah M10000, C134
DVD, 40Gig, 256MB DDR
GPS, OBD 2, Reverse Cam
Mute on stereo w I300 car kit
Liliput 7in w usb touch screen
Direct connect with BOSE-CD changer
skassama is offline   Reply With Quote
Old 02-18-2004, 10:01 PM   #20
spyhunter's Avatar
www.digitalww.com
go there and buy it you thread hijacker :-P
Alex
Old 02-18-2004, 10:14 PM   #21
well that was not the intent ... but since I have been branded, well DWW dont have ..... so are you interested in sending me yours :-)
and yes before I forget.... good write up
ALIBABA - I30 99
Nemiah M10000, C134
Old 02-18-2004, 10:18 PM   #22
spyhunter's Avatar
thanks
and oh yeah? whats this? lol http://www.digitalww.com/indashhousing.htm
Alex
Old 02-18-2004, 10:32 PM   #23
Thats what you put your lcd into ......I need the one from which your lcd came out ... like whats shown in your pic http://www.mattoree.com/z/lilliput/PICT0032.JPG and just the front bezel..... dont ask what happened to mine.. long story
ALIBABA - I30 99
Nemiah M10000, C134
Old 02-19-2004, 03:05 AM   #24
I'm having problems with my ribbon for the front panel buttons. I seperated the wires and tried soldering but I don't think they were all connected properly because I connected everything else, plugged in the power and pushed the power button and got nothing. Because a lot of the plastic got melted (also don't have the right soldering iron tip) I decided to cut off that end of the ribbon and 'restrip' it without even thinking. I assumed I could just gently cut on one side of the ribbon and peel it back exposing the wires but um... that's not working too well.
Any suggestions?
I'm sure I can play around with my knife a bit and scrape off the plastic but I'm just wondering if there's an easier way.
NS98GSR is offline   Reply With Quote
Old 02-19-2004, 03:31 AM   #25
phc
phc's Avatar
I soldered a small length of wire (~1/2" long) of 30 AWG wire to the connector where it solders to the PCB. Not an easy thing to do unless you have a pencil point soldering iron and small diameter solder.
I should have taken more photos...
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 02-28-2004, 09:48 PM   #26
spyhunter,
How did you power up the lilliput? Did you cut the power connector along with the USB connector?
Old 02-28-2004, 10:00 PM   #27
spyhunter's Avatar
umm if i recall correctly i took the usb like connector and used the supplied power adapter off of that. the cigarette lighter adapter that is...
Alex
Old 02-28-2004, 11:48 PM   #28
I understand you took out the usb like connector, but then, how did you use the supplied power adapter off that? Did you cut off the connector from the supplied power adapter too? Or did you solder them together?
Old 02-29-2004, 12:18 AM   #29
spyhunter's Avatar
hmmm ok....the supplied cables that came with the lilliput answers all questions. the screen can be powered off of the jack right on the screen or though the usb like cable which has power, video and left/right audio jacks on it. i used the cig adapter, cut off the end and put a molex connector on it to power it off the psu. that answer the question?
Alex
Old 02-29-2004, 12:26 AM   #30
Okay, I think I know what you mean, its just that I didnt understand your original post in this much detail.
It seems to me that you took out the Lilliput's USB-like connector off the board, and resoldered a USB extension cord with the 4 wires to where the Lilliput USB-like connector was.
So now you have an extended USB-like connection to the board, I dont know how long but does it extend all the way towards the end of the case where the spring was? Or just a short distance?
Assuming this is the case, you have 4 inputs now to the board,
Pin 1 red
Pin 2 White
Pin 3 Green
Pin 4 Black
Ground to Ground
or 5, including ground. Which of these pins do you connect to the +12V of your molex connector? Or do you straight away plug em in the USB port of your mobo (I understand USB connections has 12V out too right) and that's where you get the power to power the lilliput?
indash housing and lilliput? LudeAtude General Hardware Discussion 2 02-07-2004 05:31 PM
Calling all TM 701L users with GPS fyleow LCD/Display 4 01-26-2004 02:28 AM
think this housing would hold the lilliput? spyhunter LCD/Display 3 12-31-2003 07:55 AM
TM 701L Owners chut LCD/Display 25 10-08-2003 03:08 PM
