Old 02-15-2004, 03:19 AM   #1
SuperDave01 is on a distinguished road
No Signal on Lilliput 7 Inch touchscreen.
I just got my Lilliput 7 inch touchscreen monitor in the mail today. Everything looks good from the outside, and I'm pretty sure everything works correctly (touchscreen and lcd), but for some reason I keep getting a "no signal" when I connect everything to the video card. I've tried searching, and I think I've read every thread about people not getting a picture. I tried changing my resolutions to 800 X 600 @ 60 Hz, but I still get nothing. When I restart my computer, I get the "no signal" screen when the BIOS boots up, then it disapears, and I get the "no signal" screen again right when Windows XP begins to load. Thats telling me there IS a signal going to the touchscreen, but it can't recognize it. I have a GeForce 4 4200. I even tried to use a DVI to VGA converter then having a dual monitor setup to get the Lilliput going, but still no luck. I'm thinking I need some Lilliput drivers or something more specific to this monitor. Anyone have any input? Any help would be GREATLY appreciated. I've been staring at this screen for too long! Thanks all.
Dave
SuperDave01 is offline   Reply With Quote
Old 02-15-2004, 12:08 PM   #2
Raw Wave
wizardPC's Avatar
wizardPC will become famous soon enough
when you turn the screen on, does it say "VGAMODE" before it tells you that you dont have a signal?
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 02-15-2004, 02:37 PM   #3
Yes it does. Any ideas?
Old 02-15-2004, 03:46 PM   #4
Ok guys, I got it to work. It turned out that there was no problems with the software, but the hardware was at fault. One of the pins in the vga connector coming from the Lilliput were bent. I bent the pin back and pluged it in, and it worked! Next time I'll check the plugs first! Thanks for the help wizardPC.
Dave
P.S. - This screen is awesome!
Old 02-15-2004, 04:35 PM   #5
Raw Wave
wizardPC's Avatar
Quote: Originally Posted by SuperDave01
...One of the pins in the vga connector coming from the Lilliput were bent. I bent the pin back and pluged it in, and it worked...
yep, that'll do it.
I hate it when that happens cause its the last thing you'd think of
I'M DEBT FREE!!
Old 10-29-2005, 02:03 PM   #6
morteno is on a distinguished road
I'm having the exact same problem as SuperDave01 describes in his first post. I have checked both the VGA connector and the round connector from the screen, and no pins are bent.
Any other ideas?
Regards, Morten
morteno is offline   Reply With Quote
Old 05-04-2008, 04:43 AM   #7
vaige is an unknown quantity at this point
im having the same problem too... even tested all points with multimeter...any solutions to this problem??? thanks in advance!!
vaige is offline   Reply With Quote
Old 05-04-2008, 10:36 AM   #8
aleshu's Avatar
aleshu is an unknown quantity at this point
probably a cable problem, or a faulty cable connection to the board, I guess.
more suggestions:
http://www.mp3car.com/vbulletin/lcd-...ut-signal.html
aleshu is offline   Reply With Quote
7 inch touchscreen now powering up superman19 LCD/Display 10 05-20-2005 03:48 PM
Lilliput 8" Touchscreen Display Randomtask LCD/Display 6 02-06-2004 02:12 PM
exact outer size of 7" lilliput touchscreen? cotwild LCD/Display 2 01-08-2004 01:43 AM
Glare reducing material over Lilliput touchscreen?/ MikeH LCD/Display 15 01-05-2004 04:40 PM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 09:30 AM
