Old 02-19-2004, 04:54 PM   #1
Hacking my Morotized screen.
Ok so I have this screen:
I want to turn it into a VGA screen. So all I need is a VGA controller? Correct?
I already took it apart and it has the same Panasonic LCD Module that Armen sells. But do I need an Inverter or anything else?
Also what would be a good LCD Controller solution? I cant seem to find one via google.
Click Here to see my Car's Website
2003 Nissan Sentra Spec-V
Spec-V is offline   Reply With Quote
Old 02-19-2004, 05:20 PM   #2
digitalww's Avatar
What LCD panel is inside? Can you take pictures of all the components?
If it is the same LCD Panel than the Gain/Xenarc controller and inverter will work.
What about the electronics that control the motors? Are they on the main Video controller or on a separate circuit?
Let me know.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 02-19-2004, 05:36 PM   #3
Let me know.
Armen
Electronics for the motors are on a seperate circuit. The LCD Panel is identicle to the one in this pic:
Thanks for any help Armen.
Greg
Old 02-19-2004, 05:43 PM   #4
digitalww's Avatar
Then the controller (xenarc/gain) will work. If you take your LCD panel and the controller out of the housing, does it still slide in and out?
This could be a very simple mod. Just have to try. The controller will definitely work. Also you will need to figure out how to run the VGA cable.
Can you get any pictures?
Armen
Old 02-19-2004, 05:54 PM   #5
I'm at work now. I will try to post some pics tonight.
Will I still need an inverter? I never understood exactly what they do anyway.
Also how much is the xenarc/gain controller?
Old 02-20-2004, 06:41 PM   #6
Rev_BoB's Avatar
backlighting
is what the inverter is for, don't know why you need one though
As Saddam once said.."COME ON!!!"
Rev_BoB is offline   Reply With Quote
Old 02-20-2004, 07:06 PM   #7
Marsupial's Avatar
the backlight are using CCFLs, and they run on high freq AC generated from the inverters
with no inverters you have no light and can see nothing.
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Old 02-20-2004, 07:16 PM   #8
Rev_BoB's Avatar
as you can see from the picture
it already has backlighting unless I'm missing something here.
Old 02-20-2004, 08:18 PM   #9
digitalww's Avatar
The backlight still needs an inverter to power it.
Armen
Old 02-20-2004, 08:26 PM   #10
digitalww's Avatar
You will need an inverter ($10), VGA Controller and Cable ($160).
Take some pics of the mechanism if you can and every other angle inside the housing.
Armen
Old 02-20-2004, 09:03 PM   #11
Rev_BoB's Avatar
ummmm
then what would be the point of the inverter that is currently powering the backlighting?????
Old 02-20-2004, 09:35 PM   #12
digitalww's Avatar
In this particular monitor the inverter is built-in into the video controller. It is not built-in on the VGA Controller and it comes as a separate PCB. Once he removes the video controller he will have no inverter and will need one.
Armen
Old 02-20-2004, 09:43 PM   #13
Rev_BoB's Avatar
that makes more sense
and why I stated "or am I missing something"
Old 02-21-2004, 09:14 PM   #14
So what kind of monitor is it?
andyl8u is offline   Reply With Quote
Old 02-22-2004, 03:00 PM   #15
Well it does NOT look like my idea will work.
I have completely dissasembled the screen.
There are 3 control boards. One on the back of the lcd module and one in the case itself and a small one that controls the motors. All controls go through the first board (back of module) then to the main board via a ribbon cable. The main board is where power/rca input is.
Then there is a similar but smaller ribbon cable that goes to the small board that controls the motors.
I am pretty sure I could switch out the control board with a vga board. But I would have no way of controlling the in/out and up/down motors.
I wonder, Armen if I sent it to you... do you think you might be able to figure something out? I realy want to keep my motorized features, but want to be able to have a more clear display for GPS purposes.
I would pay you of course.
Let me know.
Thanks,.
Greg
To all you LCD gurus, please help me find the right screen! JuBu LCD/Display 21 08-27-2006 02:26 AM
Gamecube screen junior LCD/Display 7 11-24-2003 07:38 AM
lillyput--all hype?----long review liquid_smoke LCD/Display 0 11-21-2003 11:44 AM
Problems with screen backlight and allen controller setup MikeHunt79 LCD/Display 13 07-02-2002 11:54 AM
NEC Versa M/75 Laptop TFT screen w/touch Macgyver777 LCD/Display 23 03-24-2002 03:14 AM
