Old 02-21-2004, 05:26 AM   #1
paolo77 is on a distinguished road
BMW Z4 custom installation.....
Hallu guys.... I have a Project......I have a Z4 CID display and I would like to install it on another car.... a Smart....
This is a very interesting motorized display that I like very much....and that could give to my "little car" a "buisness" aspect.....
The problem is that BMW ( as usual .... ) don't give me the tecnical datasheet of the monitor and connector... so now I have a beautifull not-working object.........
I discovered on the net that this is a Sharp display that accepts RGB ( synk-on-green) imput signal....I'd like to use it to play DVD ( not for a carputer at the moment....) and I have to make a videocomposit to rgb converter ( I don't think that could accept directly videocomposit imput....)
but for the moment the first problem to overcome is to turn on the motor.....
I opened yhe display case and loock very well the connector... but I can see only 4 identical cable....that I could not identify.... I could only suppose :
-12 volts power
-masse
-remote
I have a white BMW connector... and I don't have found anyware the pin indications.....
Please I really wants to finish this project... I need your help...
Paolo
paolo77 is offline   Reply With Quote
Old 02-23-2004, 02:05 AM   #2
hallo again.... I finally found the connector's pin value..... so I have RGB 12 volts and the activation........The problem is activation..... it's called k-bus or I-bus....
Do you know wath kind of signal use... it "only" turn-on the display...
Paolo
Old 02-23-2004, 02:32 AM   #3
BoraXP's Avatar
BoraXP
try to find a bmw forum
BoraXP is offline   Reply With Quote
Old 02-23-2004, 11:32 PM   #4
partyd is on a distinguished road
it's called I-bus and this people will help you a lot follow the link
http://autos.groups.yahoo.com/group/...guid=116341306
partyd is offline   Reply With Quote
Old 09-06-2005, 03:06 AM   #5
carrera is on a distinguished road
Hi i have the same problem.
Have you solve?
emm can you send me the Bmw connector datasheet?
carrera is offline   Reply With Quote
Old 09-06-2005, 12:11 PM   #6
JPuma's Avatar
JPuma is on a distinguished road
wow, that housing looks very close to the shape of the AC grill in a BMW X5. I've been on a mission to try and find a way to mount my Xenarc in the X5. I already have a OBM so the best place to mount the xenarc was on the left side of the center AC vent. It looks really cool there but it would look even better if I knew how to fabricate so I can embed the xenarc into the AC vents so it looks simiar to your lcd housing but with ac vents as well.
JPuma is offline   Reply With Quote
Old 12-26-2006, 04:54 PM   #7
dragonsfiiire is an unknown quantity at this point
i have the same screen and have been looking for ansers
i have the same screen and have been looking for a wireing diagram or any help to turn on the darn thing . i have found the rgb coaxal wirers but have no clue on power or ibuss signaling. i have been looking for answers for a year and a half and have even asked a bmw micanic. if you have any info please help me by shareing it. thank for any responce.
dragonsfiiire is offline   Reply With Quote
Old 12-26-2006, 06:06 PM   #8
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
There is someone who has used one of those in his E39 or E46. Now who was it?
<goes away to think and search>
*edit found it, it's darthtater
http://www.mp3car.com/vbulletin/worklogs/87541-bmw-540i-project-part-2-a.html
try asking him as he seems to have it working.
Enforcer is offline   Reply With Quote
Trouble setting custom resolutions.... SinnerG LCD/Display 10 06-18-2003 08:15 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
Looking for keys/buttons for custom keypad izaram General Hardware Discussion 8 04-23-2002 11:58 PM
Tips & Tricks for making custom LCD cables... Please add your experiences... junfan LCD/Display 0 03-22-2002 07:40 AM
Custom Installation pacochi General Hardware Discussion 12 12-08-2000 09:18 AM
