Old 02-27-2004, 10:16 PM   #1
Registered User
Cliff
TM-701L Problem Issue - Screen goes dead (ARMEN please read)
Not sure what the cause of this could be...
Sometimes when I start my car the screen goes blank (black) and shows nothing, yet stays lit. I dont get the blue "no signal" screen, it just stays black. I hear my carputer boot up, yet the screen stays black. At first i figured it was my carputer, but after I disconnected the carputer to see if I would get the No Signal screen back, it stayed the same, black, but LIT.
I came back outside and started the car, and it was back to normal, functioning properly. Its been going back and forth. Any ideas why this would happen?
Thanks ahead of time...
Grand AMplifier Project 1.0:
http://drive.to/cliffsgrandamgt/
http://www.astallaslions.com/carmp3/
-Eden 800 mini-itx motherboard
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
-PB Remote /w Girder
-Media Engine & Windows XP
-Playstation II also added
-Steering Wheel Buttons modified for Control.
Cliff is offline   Reply With Quote
Old 03-06-2004, 11:28 AM   #2
Registered User
Cliff
bump! a week and no replies - Armen you have any ideas? It happened again yesterday, it took about 3 hours of driving and then all of the sudden the blue no signal screen popped back on, and I was able to switch my carputer on.
Im beginning more and more to think its a defective unit, but maybe I'm doing something wrong? Do these units need to heat up in the cold?
thanks
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 03-06-2004, 01:36 PM   #3
digitalww's Avatar
digitalww is on a distinguished road
It sounds like a loose connection. If you can send it back to me then I will fix it. You can also take a look at it yourself. Open the back cover to get to the controller and take a look at this ribbon cable. Check the connectors on both ends of the cable. Then reassemble it and test it. If the problem doesn't go away then definitely send the monitor back to me.
Let me know.
Thanks,
Armen
thanks
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 03-06-2004, 07:29 PM   #4
Registered User
Cliff
Let me know.
Thanks,
Armen
thanks! will do!
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 03-10-2004, 02:55 PM   #5
Registered User
Cliff
Well I tryed it and all the connections on the back look secure. I placed everything back in and the screen still is blank but glowing. I would like to send this back to you. Please check your email, I need your address again
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 03-11-2004, 06:41 AM   #6
stimps's Avatar
stimps
its most probably low voltage going into the display. Check it. or it can be overheating. I have had mine suffer both these problems, and by upgrading the wiring to it, and keeping it cool, problems went away. Now happy with my TM-701
stimps is offline   Reply With Quote
Old 03-11-2004, 08:02 AM   #7
PTCruiser's Avatar
PTCruiser is on a distinguished road
check the flat cable going from the screen to the housing...
the cable could be damaged after some time
a member of carmedia had exactly the same problem (fixed now)
check here:
http://www.carmedia.org/forum2.php?c...um=&topic=5343
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
PTCruiser is offline   Reply With Quote
Old 03-11-2004, 01:11 PM   #8
Registered User
Cliff
Well its definitely not overheating, its cold here and the screen doesn't work even when its dead cold.
The voltage thing could be the problem, I am currently looking into upgrading all the gauges of my wiring in my engine bay.
I already sent it back. I checked the connections, and all the wiring. this is a brand new unit, so nothing should be worn yet. I hope Armen can resolve the issue without it coming back the same way. Because its tempermental, sometimes it'll just pop on for 3 hours and then the next day it wont work at all, and I can't figure out what it is. Hopefully he will see this!
Thanks so much for the input though guys. I love this forum
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 03-11-2004, 01:14 PM   #9
audrenaline is on a distinguished road
I bet it's low voltage. My screen flickers when I first power up my car. Sometimes the screen won't even turn on until my car has been charged fully. I would also check the voltage that is going to your screen with a multimeter.
audrenaline is offline   Reply With Quote
Old 03-11-2004, 02:00 PM   #10
Registered User
Cliff
even after I have my car run (at high RPMs) and then restart the screen, no go. ive had voltage problems in the past so im not ruling it out compeltely.
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 03-11-2004, 02:13 PM   #11
digitalww's Avatar
I will figure it out and get your screen working
Armen
Old 03-11-2004, 02:44 PM   #12
Registered User
Cliff
Armen
hell yeah, you are the man!
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
7" LCD screen color loss problem vladilen LCD/Display 9 10-04-2003 03:42 AM
DigitalWW touch screen kit problem BoraXP LCD/Display 4 08-27-2003 10:13 PM
I know the problem but dnt know how to fix it? corsamel General Hardware Discussion 4 08-18-2003 12:11 PM
Problems with screen backlight and allen controller setup MikeHunt79 LCD/Display 13 07-02-2002 11:54 AM
Laptop tv-out problem. Not filling screen sometimes Scrapez General Hardware Discussion 4 06-02-2002 12:20 PM
