Old 03-05-2004, 02:33 PM   #1
NewTechFool is on a distinguished road
Before you use foam to mount your Touch Screen
I found this while surfing. I don’t know if this is common knowledge, but it is very useful info. I also don’t know if this is particular to the Elo screens (such as the eBay Kiosk).
• If you plan to seal your front bezel around the viewing/display area, be sure to use the Elo Volara foam, or an equivalent closed-cell and non-gas/chemical-emitting type of foam (available from DFI and other suppliers). Volara is an Elo trademark.
• This foam typically must not be wider than a quarter inch (less foam pressing on the surface-wave sensors at the edge of the glass), and the thickness of this foam can be 1/16" or 1/8".
• The adhesive side of the foam must stick to your bezel, and not the touchscreen/glass.
• Do not use a generic-type or automotive-type foam which may cause the touchscreen not to properly work -- the touch points may be totally out of calibration and cannot be recalibrated, or there will be dead zones where the touchscreen does not work, or the entire touchscreen simply will not work at all. (To debug, just loosen or remove your bezel and re-test the touchscreen functions.)
I found the information on the following page: http://dfiusa.com/p_m_download/index.html
There are some other useful touch screen tips on the page, such as what to use to calibrate your screen.
NewTechFool is offline   Reply With Quote
Where to find a touch screen overlay? bayere LCD/Display 3 01-13-2004 12:32 AM
adding touch screen kit to indash LCD??? kurtm LCD/Display 5 07-19-2003 02:17 AM
Looking for schematic of in-dash mechanical screen mount - Help please! nxt125 LCD/Display 0 07-14-2003 04:12 PM
UPDATE ON: TM-701L and Touch Screen Kit digitalww LCD/Display 65 07-12-2003 12:39 AM
FS : 12 Inch Touch Screen / 25 Foot Cable ezfilez Classified Archive 2 04-16-2003 03:08 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
