Old 03-08-2004, 12:18 AM   #1
Norrin302 is on a distinguished road
WIERD Display on Lilliput...HELP! (pic attached)
My lilliput 7" was working fine a week or so ago. I hooked everything up tonite to test it out, but now all I get is a wierd display. (pic below) The power button is sometimes off, sometimes red, but never turns green. Pressing the power button does no good. The buttons are also always blue. Teh screen is all black, then fades into white background with rainbow lines. Nothing I do seems to make a difference. Anybody have any ideas? I need some serious help...
Russ
Norrin302 is offline   Reply With Quote
Old 03-08-2004, 12:38 AM   #2
R3l0ad is on a distinguished road
looks like your verticle or horizontal synch is off. You may want to crack the back of the lilliput open and ensure that the wires that are coming from the vga cable are hooked up and soldered good. You could have broke a solder during install.
New CarPC on the way again I think. I miss my old one!!!
R3l0ad is offline   Reply With Quote
Old 03-08-2004, 12:50 AM   #3
Well, something I forgot to mention, that display comes up whether the vga cable is plugged in or not! Doesn't seem to matter.
Old 03-08-2004, 07:45 AM   #4
Anyone have any ideas what's wrong with this thing?
Old 03-08-2004, 04:20 PM   #5
The VGA wires going to the back of the controller board all look good, don't seem to be any issues there. Help!
Old 03-08-2004, 04:34 PM   #6
digitalww's Avatar
digitalww is on a distinguished road
Re-seat the ribbon cable that is connecting the controller to the LCD panel and it should fix the problem, unless the cable it self is damaged.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 03-08-2004, 05:15 PM   #7
I've tried that a few times, but I'll make sure it's in there correctly. Have you seen this before? If the cable is damaged, how would I go about getting a new one?
Old 03-08-2004, 05:25 PM   #8
Ok, re-seated it on both ends, now all I get is a completely white screen. WTF??
Old 03-08-2004, 07:21 PM   #9
masch
Something is wrong with the connection between the VGA controller and the LCD. Either that or damaged VGA controller itself.
It goes like that when the signal is not coming through properly. I've had that problem many times, and what I had to do was reseat the ribbon cable and apply some thick tape above it so that when I close the housing, it presses the controller and LCD tightly and makes sure that the ribbon cable seats firmly in the connector.
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 03-08-2004, 11:31 PM   #10
Anyone know where I can get another cable that connects the controller card to the screen? I'm thinking mine is having issues... Are tehre any tests I could do to make sure my controller card is working properly?
Old 03-09-2004, 09:45 PM   #11
Old 03-09-2004, 09:48 PM   #12
digitalww's Avatar
Check you PM box. I sent you a message yesterday.
Armen
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
Any way to relocate my display card?? SlimJimmy General Hardware Discussion 13 03-22-2004 10:14 PM
Small Lilliput display problem Da_Teach LCD/Display 17 03-01-2004 07:23 PM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
Choosing a Character display... Kryten LCD/Display 3 10-16-2003 11:43 PM
