Your sound system is drawing too much power, three solutions I can think of (and you will probably need all of them at the end of the day)
Check your existing charge circuit, maybe your alternator is not up to speed or your battery is a bit poor, also what do the battery connections look like ? maybe clean them with a bit of coca cola the run some proper gauge wire from the battery, fused of course, dont trust the stock wiring, then maybe a power capacitor, or even a second battery.
The dimming is caused by the bass sounds, even without a sub, this causes a voltage drop of maybe half a volt or more, if you have a multimeter, you can measure this and see what I am talking about, the thicker wire will help a little, the power capacitor a lot and the second battery will prevent this from happening, if you dont address these issues chances are you will destroy the "backlight" of the lcd or the controller card for it
