Old 03-19-2004, 02:36 PM   #1
This thing any good for easy LCD mounting?
Hey .... found this at mobilevideo4less.com:
http://www.mobilevideo4less.com/Merc...duct_Code=MSBT
Looks like it might be an easy way to mount an LCD without having to cover up your AC vents like you would do if you used those clips at theclip.com. Anybody ever try this thing out? By the looks of it, though, it seems it might be ok for just being used as a display, but if your LCD is a touchscreen it might be too flimsy for that (I'm guessing it'd probably shake too much on a bumpy road).
WWE-TicK is offline   Reply With Quote
Old 03-19-2004, 02:47 PM   #2
sfay93's Avatar
You are correct. The monitor would shake all over the place while you were driving. Terrible for touchscreen as you wouldn't have anything to push against(aside from your dash behind the monitor).
sfay93 is offline   Reply With Quote
Old 03-20-2004, 03:10 PM   #3
It would be fine for use as a monitor mount. The amount of resistance the flex has is enough to minimze bounce. And i wouldnt be worried about pussing the monitor back from using the touchscreen. How do i know? Cause i use a flex mount...not this model, but a similar.
[H]Bugster is offline   Reply With Quote
I want a lcd... but is this a good one for my needs? Shizank LCD/Display 14 07-05-2004 12:43 AM
Running into some issues mounting LCD briang LCD/Display 3 03-15-2004 01:54 AM
[Aus] Unipac LCD, Any good? aphesis LCD/Display 68 11-13-2003 08:10 AM
Chevy Blazer LCD location good? Opinions? mclife11 LCD/Display 11 08-15-2003 02:44 PM
Flex-arm mount , good for LCD or keyboard gizmomkr Classified Archive 4 02-19-2001 04:17 PM
