Old 01-30-2005, 12:53 PM   #181
Done the power-mod myself too.
I also have a later revision of the Lilliput, same as PHC, with 5 instead of 4 resistors. I also had some problems with the front-buttons, which didn't work anymore after putting my screen back into 1 piece.
Also made some pictures, since the previously posted pics weren't that good focussed. (However the resistor isnt focussed well on the first picture, using macro on my cam with additional lenses gives a VERY small DOF. (Canon A70 with +5 macro lense)
I used the 150k resistor as in the first post by Coyote. I saw PHC used another value for the resistor, but I stuck with the original mod and it works for me.
The flatcable to the front, for the buttons, can be connected in 2 ways. You have to connect it as on this picture, so its aligned at the left side. (See the space at the right side of the ribbon)
DJSmiley is offline   Reply With Quote
Old 01-31-2005, 12:51 PM   #182
strohmrs's Avatar
Coyote,
I had my Lilliput apart for another project and decided to try your mod. Took less then 5 minutes and it works great. Helps to have the right parts and equipment on hand! Thanks for sharing!
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
strohmrs is offline   Reply With Quote
Old 01-31-2005, 01:01 PM   #183
MySQL Error
MatrixPC's Avatar
I don't remember exactly which is left or right, but you have to put that flat ribbon cable closer to the IR sensor. That is how I put a note to myself when I put the darn thing back.
By looking at the picture, if the IR sensor is to the right, then you have to move the cable to far to the right.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-31-2005, 01:06 PM   #184
Well, on my photo the IR sensor is on the left, so the pic is made in WORKING state (the small part of the black thing on the left is the IR sensor)
Old 02-05-2005, 03:15 PM   #185
See me in my wet t-shirt.
stevieg's Avatar
Done the mod, it works... I'm VERY happy!
Ford Focus MP3 : www.stevieg.org/carpc
Car PC Status: COMPLETE
stevieg is offline   Reply With Quote
Old 02-05-2005, 04:20 PM   #186
Confusion Master
Enforcer's Avatar
I was looking into doing this, however I seem to have found another way
http://www.mp3car.com/vbulletin/show...98&postcount=8
Enforcer is offline   Reply With Quote
Old 02-20-2005, 07:35 PM   #187
I just used this circuit and it worked great! I am mounting the monitor flush behind my double din dash opening in my mk3 Supra and I will not be able to reach the buttons so this really helps me out! Thank you very much!
bigaaron is offline   Reply With Quote
Old 03-15-2005, 11:58 AM   #188
<Echo>Anyone done this with a new 8" lilliput yet?</echo>
Arathranar is offline   Reply With Quote
Old 03-21-2005, 11:30 AM   #189
looneeii's Avatar
Arathranar I'm awaiting the same info....
99 Grand Prix Grand Tigress
HW
Liliput 8in TS
845GVD MITX w/ 2.4 Mobile P4M (478 MB)
60GB 2.5" HDD
MS MN-710 WifiG
BT Deluo lite GPS
IrDa PS/2 Keyboard
SW:
Win XP SP2
RR
IGuidance 4.0
Zots day skin
Proscan 4.0
(100% Complete!)
looneeii is offline   Reply With Quote
Old 03-21-2005, 12:02 PM   #190
SOS
Did this on 2 7" lilliputs, worked perfectly!
SOS is offline   Reply With Quote
Old 03-24-2005, 07:51 AM   #191
looneeii's Avatar
Kinda off-topic, but as an alternative how would you solder an external on/off switch to liliput instead of leaving it auto-on because I don't need to drain my battery the way I have it setup in my GP. Thanks.
HW
Liliput 8in TS
60GB 2.5" HDD
MS MN-710 WifiG
BT Deluo lite GPS
IrDa PS/2 Keyboard
SW:
Win XP SP2
RR
IGuidance 4.0
Zots day skin
Proscan 4.0
(100% Complete!)
Old 03-24-2005, 08:13 AM   #192
Use a relay to switch the batteryline on/off from the ignition key...
Old 03-24-2005, 08:17 AM   #193
looneeii's Avatar
HUH?
HW
Liliput 8in TS
60GB 2.5" HDD
MS MN-710 WifiG
BT Deluo lite GPS
IrDa PS/2 Keyboard
SW:
Win XP SP2
RR
IGuidance 4.0
Zots day skin
Proscan 4.0
(100% Complete!)
Old 04-01-2005, 12:49 AM   #194
phc
phc's Avatar
FYI - Mod made simpler.
By leaving the resistor in, I've added just one 150uF capacitor and it works fine.
Getting a 150uF cap is tough, especially one that is not huge. I found a 6.3V one in DigiKey that is pretty good.
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 04-01-2005, 12:58 AM   #195
Cool!
But has anyone tried this with an 8" lilliput yet? Last time I tried to mod something based on a 'similar' model, I ended up buying a replacement hud.
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
