Old 04-01-2005, 04:53 AM   #196
lazarus's Avatar
despite haveing done no mods to my 7" lilliput it turns on by its self any way. its the newer revision of the board and its hooked up to an opus 90watt psu (positive and ground), i also remove it completely from the car on a night so it has kind of back up power but still it fires up by its self in the morning. when i get the a chance i'll go and check if there are any model/revision numbers on the back to compare against.
lazarus is offline   Reply With Quote
Old 04-01-2005, 11:24 AM   #197
MySQL Error
MatrixPC's Avatar
Quote: Originally Posted by phc
FYI - Mod made simpler.
By leaving the resistor in, I've added just one 150uF capacitor and it works fine.
Getting a 150uF cap is tough, especially one that is not huge. I found a 6.3V one in DigiKey that is pretty good.
Quote: Originally Posted by joshthepilot
Since 100K and 10uF work, 100uF cap would also work in this setup.
I pointed this out on page 2 of this thread (post 29) but no one try it.
http://www.mp3car.com/vbulletin/show...6&postcount=29
Post 30 is Coyote reply
http://www.mp3car.com/vbulletin/show...8&postcount=30
[edit]correct link to Coyote post 30 [/edit]
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-01-2005, 01:34 PM   #198
MySQL Error
MatrixPC's Avatar
Yes you did. And now that I see it, I wish you would have rebutted against that this could be damaging.
The cap, regardless of size really has the same effect as the button. There is no way the charge would damage the mcu, the circuit, or the power button.
You have done it this way Matrix? And if so, tell us how well it works.
Nope I didn't mode my LCD for this auto on yet that is why I don't know how it works and how reliable it is.
Old 04-06-2005, 11:03 AM   #199
looneeii's Avatar
Anyone do this on the 8in liliput yet?
99 Grand Prix Grand Tigress
HW
Liliput 8in TS
845GVD MITX w/ 2.4 Mobile P4M (478 MB)
60GB 2.5" HDD
MS MN-710 WifiG
BT Deluo lite GPS
IrDa PS/2 Keyboard
SW:
Win XP SP2
RR
IGuidance 4.0
Zots day skin
Proscan 4.0
(100% Complete!)
looneeii is offline   Reply With Quote
Old 04-12-2005, 05:31 PM   #200
works on lilliput 8" TS too.
the circuit is slightly different, with the switchboard connector on back rather than front, so I routed the - wire of cap through a hole to back to get a ground point, but front side is same.
ming is offline   Reply With Quote
Old 04-12-2005, 05:35 PM   #201
Ooh! Thank you! Please post (many) pictures!
Arathranar is offline   Reply With Quote
Old 04-12-2005, 08:34 PM   #202
the board is mounted on the back of the casing. second photo shows the whole board and 1st is how I soldered the resistor and capacitor -- the original resistor was removed. 3rd image shows where I grounded the cap on the back side.
Old 04-12-2005, 11:56 PM   #203
looneeii's Avatar
Very nice, thanks
HW
Liliput 8in TS
60GB 2.5" HDD
MS MN-710 WifiG
BT Deluo lite GPS
IrDa PS/2 Keyboard
SW:
Win XP SP2
RR
IGuidance 4.0
Zots day skin
Proscan 4.0
(100% Complete!)
Old 04-13-2005, 12:09 AM   #204
fantomas's Avatar
do the lights on the bottom stay on constantly now for the 8" as well?
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 04-13-2005, 01:01 AM   #205
What size cap / resistor did you go with? Ok - I know I could work out the resistor by digging up the details on how the color code but I'm sure you won't mind letting me take the easy way out by telling me .
Old 04-13-2005, 06:38 AM   #206
Raw Wave
shotgunefx's Avatar
Any specific reason to use an electrolyte cap as opposed to a non-polarized mylar or more rugged Tantalum cap?
shotgunefx is offline   Reply With Quote
Old 04-13-2005, 08:28 AM   #207
I used values in coyote's post -- 150k resistor and 10uF cap. I didn't pay attention to what type of cap, but for 10uF probably Al electrolytic ones are most common and cheap, I got a 20 assortment pack from radioshack for $4.29.
I think the button lights work as they should be, but I didn't pay much attention to that.
Old 04-13-2005, 10:31 AM   #208
Its a different mod for the lights.
Old 04-14-2005, 01:51 AM   #209
phc
phc's Avatar
Capacitor selection depends on many factors, Tantalums are great for voltage regulation to supress high frequency oscillations and have low ESR. Film caps are good for high voltage spikes, low leakage, etc..
In the case of the lilliput, you have a 5V signal that you are trying to delay. Super low frequency, super low voltage. No need to spec anything but a cheap-*** aluminum electrolytic, rated to 6.3V.
I use a 150uF, in combination with the on-board 10K-ohm resistor, giving you an RC value equal to a 150 k-ohm resistor with 10 uF cap.
23 cents at digikey
http://rocky.digikey.com/scripts/Pro...&M=UHE0J151MDD
Putting in a more expensive capacitor won't make it work any better.
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 04-14-2005, 03:01 AM   #210
Raw Wave
shotgunefx's Avatar
Thanks for the answer. I'll probably use the tantalums as I have tons of them.
23 cents at digikey
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
