Old 05-25-2005, 06:45 PM   #226
trance728's Avatar
so i grabbed a 100uF capacitor, its 35v, is that right? also can i screw up my monitor if i tag the wrong resistor, i want to check first before i solder but i don't want to fry anything if i touch the wrong one?
trance728 is offline   Reply With Quote
Old 05-25-2005, 06:51 PM   #227
Of course you can destroy your monitor if you connect the wrong points. Be very careful.
Arathranar is offline   Reply With Quote
Old 05-25-2005, 06:53 PM   #228
trance728's Avatar
my setup - finally
http://www.mp3car.com/vbulletin/showthread.php?t=50494
Old 05-26-2005, 03:26 PM   #229
trance728's Avatar
bump
my setup - finally
Old 05-27-2005, 02:10 AM   #230
phc
phc's Avatar
Adding a CAP won't damage anything, if it doesn't work, pull it off. A 6.3V or higher CAP will work. 35V is fine.
Make sure you don't solder bridge nearby connections, check with a meter or continunity tester.
Its easier to solder to the cap to the resistor than the pin on the chip, so find which resistor is directly connected to the pin.
Good luck.
And don't solder with any power connected to the board. Unplugg all connections first.
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 05-27-2005, 01:01 PM   #231
FYI: Works on new Lilliput
For those checking this thread out and are seeing 5 small resistors instead of 4 where you connect power, and you have a new 7" lilliput, the mod still works. I've attached a pic of my install.
TO_SC300 is offline   Reply With Quote
Old 05-27-2005, 01:05 PM   #232
Also, as a quick FYI for those with other lilliputs, this mod should work with a bit of research. From the little board with all the buttons on it, where the ribbon cable connects to, you just need to trace back some connections:
1) Main power - the thick tracks on the board, it will also connect to one side of the power button
2) Power button
3) Power LED
These three points will trace back to the ribbon connector, then map that back to the main PCB. The mod gets +5v from the LED connection (one end of the 150K resistor) and then the other end attached to the + side of the capacitor which also attaches to the trace for the power button. This is where you're supposed to remove the existing surface mount resistor. Then connect the - side of the capacitor.
Old 05-27-2005, 01:37 PM   #233
Banned
RPM_VR4's Avatar
FYI: This mod is not needed anymore: http://www.mp3car.com/vbulletin/lcd-display/50258-lilliput-programming-guide-more-reset-codes.html
RPM_VR4 is offline   Reply With Quote
Old 05-27-2005, 02:06 PM   #234
trance728's Avatar
it is if u screwed up ur cable like me
my setup - finally
Old 05-27-2005, 02:10 PM   #235
trance728's Avatar
2) Power button
3) Power LED
i wanted to go the way of just using the 100uF cap and no resistor, how do i go about that, do i need to remove anything or just attach one side of the cap to ground and the other to that point on the main pcb?
my setup - finally
Old 05-27-2005, 05:28 PM   #236
Similar problem, but different
I have a 10.4 touchscreen from Dynamix Computers. My problem is that the same button that turns it on, also switches between the 3 video inputs. I pulled a lead from the UC side of the existing power button, and hooked it to one side of a momentary switch, with the other side to ground. I just push this button to turn the screen on. No, in my install, the 'factory' button was not accessible.
So, I was thinking...could I build a circuit like this one, and make it external, on the wire I brought out? Where this circuit has 5v, mine would have 12 (vehicle power). Also, with my monitor, if you hold the button too long, it will switch to the other inputs, and eventually off. Just about 1 second seems to be about right. Varying the capacitor and resistor values would fix that.
Problem is, I've just exceeded my electronics knowledge. Anyone want to start me in the right direction with component values? Please??
Toby J.
Because is offline   Reply With Quote
Old 05-27-2005, 05:46 PM   #237
MySQL Error
MatrixPC's Avatar
Toby J.
I am not sure if the Lilliput solution will work for you but this is another solution that will work. Constant to momentary circuit.
From the12Volts relay page
Base on that circuit. Tap 2 wire from the power button 2 pins and connect to the relay pin 87 and 30
There are some similar circuit posted in the hardware dev forum sticky post "diagram, schematic ... " as well.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 05-27-2005, 06:04 PM   #238
Great stuff...thanks!
If I put a ground on pin 87, instead of 12v, it will give me the momentary ground I need to fire my monitor.
Thanks again...
Toby
Old 05-27-2005, 06:55 PM   #239
d_sellers1's Avatar
I've used the above circuit to "push the power button" on my carputer. When it received the +12V ACC the circuit would engage for about a second and then stop thereby simulating pushing the power button.
It made it easier than manually starting the computer which was behind my back seat at the time. I did not want to run a switch to the front of the car because I wanted it to automatically turn on and I did not have my OPUS yet (which will get installed when I get back from Iraq).
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 05-29-2005, 01:15 AM   #240
I also have a dynamix screen that has a common power and source button.
I have found that powering it on, and then holding the power switch down for 4 seconds will turn it on.
Can anyone take a swing at what value capacitor should be used to give a momentary on of ~4 seconds?
I do not think it is as simple as assuming since a 1k uF cap gives you 1/2 second, that 8k uF will give you 4 seconds, right?
sivart321 is offline   Reply With Quote
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
