Old 04-11-2007, 07:27 AM   #256
ThunderStick's Avatar
Quote: Originally Posted by tom_rosenback View Post
Is the Coyote mod possible to apply to this 7" TFT Touchscreen Monitor CM13 from Carlights.de It would be nice to get this feature into my screen as well... Many thanks!!
//Tom
Is it a lilliput screen, Same model that he was using a few years ago. I am guessing you will be out of luck with trying this.
This thread is a little dated....
HELP MY KIDS SCHOOL CLICK HERE
New Age- Garmin Style Skin for RR
"Your two cents are worthless pennies if you consider the exchange rate for my 2 cents"
ThunderStick is offline   Reply With Quote
Old 04-11-2007, 07:27 AM   #257
jadz's Avatar
For all of those with Lilliputs, you should be using the soft mod, NOT hardware mod.
jadz is offline   Reply With Quote
Old 04-11-2007, 10:23 AM   #258
MySQL Error
MatrixPC's Avatar
If you can made my auto on via soft mod, I'll buy you a pack of beer.
I have 2 Lilliputs (619) in my hand. One is okay with soft mod first time I try. The other I have been trying for years with all tricks in those thread, and still didn't work. Jam the button work for me instead.
So far, there are 3 different mods to make the lilliput auto on.
- Soft mod
- RC mod.
- Jam the button mod.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-11-2007, 01:25 PM   #259
Raw Wave
shotgunefx's Avatar
- Soft mod
- RC mod.
Out of curiousity, did you try programming the lilliput that couldn't be programmed with the remote from the one that can?
The soft mod doesn't work for my 8" lilliput, though I believe it's probably just a different code or something.
I went nuts trying it for one last time last week. No go, but I did get some interesting behavior out of it. I tried various combinations involving the "-/--" key on the remote and got it to glitch a few different ways.
The most interesting was, if I hit "-/--" after powering on, after the signal was on, but before "VGA" went away, I could not power down the screen on the first try, only the second and even then, the lights stay on in the front. I was able to repeat this about 50% of the time.
shotgunefx is offline   Reply With Quote
Old 04-11-2007, 04:08 PM   #260
MySQL Error
MatrixPC's Avatar
The only thing I haven't try yet was swapping the internal part like the button board. Both remote work on the one that can but not the other. The problem I think is teh lilliput itself (Older design I think).
I'll swap the button board and try that sometime.
Old 04-16-2007, 12:43 AM   #261
tom_rosenback's Avatar
I now fixed the auto-power on my Carlights CM13 touchscreen. I soldered a jumper wire over the power button... Works like a charm!
tom_rosenback is offline   Reply With Quote
Old 06-10-2007, 12:38 PM   #262
I have an 8" Liliput touchscreen. When I enter "588998" on the remote, a screen comes up with a list of language options (English being the top option). I can't get the system past this screen.
I've tried every button on the remote, and nothing gets me to another menu, or allows me to input a code (I've tried entering the code anyways, no result).
Anyone have any pointers?
StaticDet5 is offline   Reply With Quote
Old 07-20-2007, 04:23 PM   #263
I have the same problem, anyone figured it out?
P.S. If you still have the problem, here is the solution
finaldude is offline   Reply With Quote
Old 10-15-2007, 02:03 PM   #264
loginfailed's Avatar
I just did the hardware/soldering mad that coyote posted and it works great. I never was able to get my screen into that menu to make it do it thru the software so I spent a few dollars at radio shack and the problem is solved.
Thanks coyote~
loginfailed is offline   Reply With Quote
Old 06-02-2008, 04:52 AM   #265
i tried avoiding using Coyotes method of caps and resistors, because im not to confident on such a new screen, I tried cable tying around the buttong and tightening it down, but it ended up snapping the solder joints of the button and the button fell off.
So i just soldered a little piece of wire across the 2 button joints, so now its AUTO on
AWSOME!
daviboy is offline   Reply With Quote
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
