Old 04-16-2004, 06:33 AM   #61
MediaCar Developer/Moderator
coyote is on a distinguished road
Quote: Originally Posted by Ricky327
But I seriously still think the 150K is far to high to act as a reliable pull up. Standard pull up are 10-47K. The original was 10K and jumping all the way to 150K may have some effect.
But if it work for you guys reliably then dont fix it
It work very fine for everybody with this resistor value, the possible noise on this µC input is very low because there is not long wire on it or other "noise receptor", then pull up with 150K is really not a problem for this application.
www.media-car.fr.st
The first Belgian PC fully integrated in a car :)
coyote is offline   Reply With Quote
Old 04-16-2004, 09:44 PM   #62
technopsych's Avatar
technopsych is on a distinguished road
Little more help with this mod...
I have a Lilliput 619GL-70NP and I need a little help. When Coyote says to remove the resistor, is the resistor that the little metal piece with 103 engraved on it? (I guess I was looking for something else). Also, was the consensus that a 100K resistor would also work for this mod? Thanks..
technopsych is offline   Reply With Quote
Old 04-17-2004, 01:23 PM   #63
cadence117's Avatar
cadence117 is on a distinguished road
Quote:
i just shorted out the power button but this is a much better solution
Wait, so can we just short out the power button and get the exact same effect as coyotes soldering solution?
If so how do you actually short out the power button...? (in noob terms)
cadence117 is offline   Reply With Quote
Old 04-17-2004, 03:14 PM   #64
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
like this:
http://gallery.jackshakes.com/carpc-...cd_powerjumper
coyote's solution is better tho ... as the way i did it is the same as if you held down the power button all the time. the other buttons don't work anymore, but you can still use the remote.
coyote's solution actually is a lot better as it simulates pressing and then releasing the power button.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 04-17-2004, 09:10 PM   #65
nick9871 is on a distinguished road
Hey the only cap i could find is 10 uf but at 120 volts!!! i take it the 150k resitor makes it 5 volts? or do i need a 5 volt 10 uf cap?
nick9871 is offline   Reply With Quote
Old 04-17-2004, 09:45 PM   #66
josath is on a distinguished road
on capacitors, the voltage is just the MAX voltage you can charge it to. so as long as it is > 5, you should be fine.
josath is offline   Reply With Quote
Old 04-19-2004, 04:11 PM   #67
Bravellir's Avatar
Bravellir is on a distinguished road
I do not know **** about electronics, and the guy where I just bought the materials for this mod knows even less than I do , and it asked the voltage the 150K should be.
I bought a ¼ v 150K is this ok? Also, how can I identify and be sure I was given the correct resistor?
I just reread the whole thread and I couldn’t find any reference to this.
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status -->
Lilliput Installed (not indash yet..)
BraveCar 2.5
Bravellir is offline   Reply With Quote
Old 04-19-2004, 04:26 PM   #68
Raw Wave
Ricky327
The resistor should be coloured brown,green,yellow,gold.
1/4watts are standards if you wish you can use 1/8watts, they are much smaller.
The capacitor is also fine, get a 16V one if you wish...again they should be smaller in size.
Ricky327 is offline   Reply With Quote
Old 04-20-2004, 07:34 AM   #69
jhwelsh is on a distinguished road
I did my mod with the 10uF cap and a 1/2 watt 100k ohm resistor. I'll let you know if it hurts it in time.
jhwelsh is offline   Reply With Quote
Old 04-20-2004, 03:46 PM   #70
Bravellir's Avatar
Tanks, it checks.
I will give it a try this weekend and post results.
Brave
Status -->
BraveCar 2.5
Old 04-20-2004, 11:44 PM   #71
c0rrupti0n's Avatar
c0rrupti0n is on a distinguished road
HEY GUYS! I got it working... It turns out that all it was, was the resistor... I changed it and that solved my problems... Coyote is a ****in pimp... Keep up the witty fixes!
c0rrupti0n is offline   Reply With Quote
Old 04-21-2004, 12:09 AM   #72
Raw Wave
Ricky327
What was the problem then? wrong value? too high? too low? faulty resistor?
Be more specific man.
Coyote are you really a pimp?
Old 04-21-2004, 12:13 AM   #73
FLA
gospeed.racer's Avatar
gospeed.racer is on a distinguished road
He was specific.....back a few pages..
"I just noticed something... I think i might of purchased the wrong resistor... I purchased a 150-ohm, 1/2 watt, 5% tolerance package of resistors at Radio Shack. I seem to be missing the K. Could i be right? Is there a 150 ohm resistor and a 150k resistor?"
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 04-21-2004, 12:16 AM   #74
Raw Wave
Ricky327
Ahh..ok hes the one who missed the K.
Cheers speed
Old 04-21-2004, 12:23 AM   #75
FLA
My Pleasure.....
gotta have something to do while trying out unattended XP installs
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
