Old 05-10-2004, 07:14 PM   #106
nick9871 is on a distinguished road
Uh What battery? My car battery or the cap that i put on the lilliput?
nick9871 is offline   Reply With Quote
Old 05-13-2004, 08:34 AM   #107
RYAD is on a distinguished road
Isent it easier to shortcircuit the poweron button and connect the 12v powercable to atx power???? I´m new to this but have lots of mainstream knowledge.... Sinse I only want to power on my lilliput when my pc is on this would be an easier solution....
Any one with skillz...... Does this work or will i damage the screen???
RYAD is offline   Reply With Quote
Old 05-13-2004, 08:41 AM   #108
wkolodny's Avatar
wkolodny is on a distinguished road
Thats the route I went with. I was afraid I would screw up the board. Very tiny solder connections.
http://www.mp3car.com/vbulletin/show...8&postcount=13
Don't Fear The Gurkey
Click here to check out My Setup
wkolodny is offline   Reply With Quote
Old 05-13-2004, 01:06 PM   #109
JayKaye's Avatar
JayKaye is on a distinguished road
Yeh this should work fine.
Personally I am using the 12v regulator that came with the lilliput. When the PC turns on it powers a relay switch which turns both my amps on, turns my EQ on (all via the remote wire) and powers my screen up. I found it safer this way, just in-case.
JayKaye is offline   Reply With Quote
Old 05-13-2004, 01:20 PM   #110
jaff_fox is on a distinguished road
I've been using this same technique for 16 months.. it works a treat and everything comes one and goes off when you turn the pc on/off
jaff_fox is offline   Reply With Quote
Old 05-13-2004, 06:30 PM   #111
[iG] is on a distinguished road
Not sure if this has been answered before but. the - on the cap connects to this little pad correct (image below)? not 100% clear from coyote's pic.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 05-13-2004, 08:00 PM   #112
CRCinAU is on a distinguished road
Yes, that's the pad...
CRCinAU is offline   Reply With Quote
Old 05-13-2004, 08:13 PM   #113
i figured there is nothing else it could possibly be, so i went ahead and connected it to that pad Everything worked flawlessly! but thanks for the reply!
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Old 05-23-2004, 01:22 PM   #114
musicthebee is on a distinguished road
plese pict coyote's picture
Can somebody please post the picture on the first page? Its not available anymore...
musicthebee is offline   Reply With Quote
Old 05-23-2004, 01:56 PM   #115
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
looks like coyote's site has gone down, or something.
Enforcer is online now   Reply With Quote
Old 05-23-2004, 04:00 PM   #116
the_dude is on a distinguished road
Anyone tried this mod on an 8" Lilliput? I'd prefer not to be the first on the 8".
- Kyle
the_dude is offline   Reply With Quote
Old 05-24-2004, 12:58 AM   #117
Registered User
aoLhaTer's Avatar
aoLhaTer
so....i would power the lilliput with power from my opus psu, right?
and how do you know the correct polarity for the cap?
aoLhaTer is offline   Reply With Quote
Old 05-24-2004, 04:28 AM   #118
Confusion Master
Enforcer's Avatar
The cap should have a line of minus signs down one side. if it doesn't it's probably not a polarised one.
Powering the lilli off your PSU is a possibility, just depends on what power it is and how much the computer draws. You should use it's own regulator + lead and connect to a 12V source.
Old 05-29-2004, 03:17 PM   #119
Can somebody please post pictures that would show things in more detail especially the soldering the pad. Would really appreciate you can post multiple pisctures to show more details. Hope you understand that I am gonna be doing this for the first time and hence wanna play safe...
Old 05-29-2004, 06:06 PM   #120
phatbimmer is on a distinguished road
well i have soldered before. i soldered a chip onto my xbox and i did this the other day and messed up pretty bad. I burned the track and i could no longer solder anything to the board. It was my own fault, i went and bought a 80 watt solder, i guess it got too hot. i was pretty sad, but i had a local stereo repair shop fix it and re-lay the track. so just a warning, BE CAREFUL when you do this! the board is very small and delicate! dont make my mistake!
phatbimmer is offline   Reply With Quote
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
