Old 06-04-2004, 06:44 PM   #121
crosseye's Avatar
crosseye is on a distinguished road
I just did this mod and the screen powers up when the power supply is turned on with no problem... but the screen is completely white. Any ideas? Either the backlight is too bright, or the LCD got screwed up somehow. Anyone have similar problems?
crosseye is offline   Reply With Quote
Old 06-05-2004, 12:40 AM   #122
JayKaye's Avatar
JayKaye is on a distinguished road
I got a similar problem where the contrast and brightness is 100%. I cant put it down as I cant press any other buttons on the screen. I am running the mod and I double checked to see if I hadnt accidentally connected the 2 pins on the power button, but all seems good with my soldering etc..
I had a problem with the cap + resister before. So replacing them will be the first thing to try.
JayKaye is offline   Reply With Quote
Old 06-12-2004, 04:42 AM   #123
Supermike's Avatar
Supermike is on a distinguished road
Thumbs up
Great Mod, but I did have a problem.
I had done everything as per the instructions in this thread, and everything was good (Cap gave a beep prior to being installed with a continuity tester). When I started it up however, the screen was very dim and there were wavy lines thru the screen . The remote still worked and it seemed to be otherwise functional.
I took it back to the bench and looked it over very closely with a flashlight, and noticed that there was some white hair like stuff still in the area of the resistor that was removed. I carefully scraped it away and tried it again - worked perfectly .
The residual resistor material was barely visible, and was kinda hair like so if you are having a similar problem you may want to check this area before you tear everything apart.
Supermike is offline   Reply With Quote
Old 06-12-2004, 09:33 AM   #124
Skuzzle is on a distinguished road
Jobs a goodun and it seems to work. Only prob was i got supplied with the wrong resistor and instead of simulating a 1.5 sec press is it right to assume it would just alter the amount of time the button is pressed for as it seems to be around 3 secs
Would this damage it in anyway ?
Skuzzle is offline   Reply With Quote
Old 06-23-2004, 07:16 PM   #125
Litespeed is on a distinguished road
Thanks so much Coyote! I just did this tonight and it worked like a charm! You da man!
Litespeed is offline   Reply With Quote
Old 06-26-2004, 03:15 PM   #126
Soul is on a distinguished road
Quote: Originally Posted by phatbimmer
well i have soldered before. i soldered a chip onto my xbox and i did this the other day and messed up pretty bad. I burned the track and i could no longer solder anything to the board. It was my own fault, i went and bought a 80 watt solder, i guess it got too hot. i was pretty sad, but i had a local stereo repair shop fix it and re-lay the track. so just a warning, BE CAREFUL when you do this! the board is very small and delicate! dont make my mistake!
80 watt
I use a 15 watt solder iron for all my small electronics work and it works great
Soul is offline   Reply With Quote
Old 06-27-2004, 01:37 AM   #127
XxAndyxX's Avatar
XxAndyxX is on a distinguished road
Quote: Originally Posted by NewTechFool
Well because applying power to the monitor does not turn it on. You still have to press the 'on' button.
Okay, I have a Xenarc screen and it does it automatically... I guess that's another reason to go with Xenarc.
XxAndyxX is offline   Reply With Quote
Old 07-09-2004, 05:10 PM   #128
digglerd is on a distinguished road
Does is matter what wattage the resitor is for this mod?
Do they list the caps by other numbers as well?
It seems that there are a lot of parts that match these specs (10uF cap and 150K resistor) but have many other variables like wattage and MDB (?) I just want to make sure I buy the correct pieces.
I bought a 1/4 watt 150k resistor and its blue rather than brown. Will this work?
digglerd is offline   Reply With Quote
Old 07-21-2004, 12:18 PM   #129
savante's Avatar
savante is on a distinguished road
The capacitors frequently used in small electronics can be labeled with a 3 number system where the first two numbers are the value in pico-farads and the third number is the multiplier. But I can't say for sure if they number the capacitors that way to values as large as 10uF. Under that schema it would mean a '106' would be a 10uF but Im not sure '6' is an acceptable value for the multiplier.
Check here for more info.
Depends on where its blue...
If one of the stripes are blue chances are its not a 150k resistor.
This is a very handy tool for determining resistance values from the color code.
And if you know a resistor value and are trying to get a color code for it, you can look here.
Hope that helps.
savante is offline   Reply With Quote
Old 07-24-2004, 12:37 AM   #130
cadence117's Avatar
cadence117 is on a distinguished road
just short the on button...
the whole process is much much easier
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
cadence117 is offline   Reply With Quote
Old 07-25-2004, 11:04 PM   #131
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
*whew* Mission complete. Returning to base.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 07-30-2004, 11:23 PM   #132
Xtreme2k2's Avatar
Xtreme2k2 is on a distinguished road
what do u mean "remove this resistor"?
Xtreme2k2 is offline   Reply With Quote
Old 08-06-2004, 06:26 PM   #133
slboytoy is on a distinguished road
Well for my Lilliput, I didn't have the same ground as the picture.
But the mod works great. Now I don't have to lean forwards and push a button! ha ha. Love being lazy
slboytoy is offline   Reply With Quote
Old 08-27-2004, 01:22 PM   #134
johnnyutah36 is on a distinguished road
Ok I went to an electronics parts store to get the capacitor and resistor. The guy ask what volt capacitor. I told him what it was for and he gave me a 10uf 63v is that gonna get the job done? what volt is the one in the pic?
johnnyutah36 is offline   Reply With Quote
Old 08-27-2004, 01:27 PM   #135
This is not an actual picture of it but is looks like this
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Complete solution, COMPUTER, SCREEN +DVD player for your car! wrxmaster Classified Archive 6 07-09-2004 03:26 PM
Power button for Digitalww 7" touch screen imi1232000 LCD/Display 0 02-15-2004 12:02 AM
Lilliput and adding another screen.. Custommx3 LCD/Display 3 01-28-2004 06:05 PM
Power Acoustik 5.6" Lcd screen HELP!!! trilogy98 General Hardware Discussion 1 09-05-2000 11:29 AM
