Old 03-30-2004, 06:23 PM   #1
kiltjim's Avatar
USB Extension, Lilliput TS?
Just installed my Lilliput TS, and have more than a few problems, but enough personal information....
I have my Lilliput in my dash, and my laptop in the backseat. I need to extend the USB aspect of the screen, and it doesn't seem to be working. If I plug the monitor directly into the computer, it works fine. If I plug the monitor into the USB extension cable, it stops working, and even fails to recognize that I have something plugged into it.
I am fairly sure that my extension cable isn't bad, so what could be a solution to this?
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 03-30-2004, 06:36 PM   #2
mutilator's Avatar
i had the exact same problem, i ended up buyin a powered usb hub, but when i plugged it in, it worked fine without being powered ??? so it worked just from bus power. wierd. try a different usb extension.
hope that helps.
tom.
Car: 2005 Mini Cooper Convertable
Status: startin from scratch. [|--------]
Hardware:
EPIA 1000M
Dlink USB radio
7" In dash touchscreen
Harmain GPS unit
RF remote
ODB2
....IBUS comin soon
Running: media engine
mutilator is offline   Reply With Quote
Old 03-30-2004, 06:56 PM   #3
kiltjim's Avatar
I just checked my cable, and it does work for a usb mouse. And the mouse does say that it takes 500mA, so the cable can support high drain devices...
Still need to check it against another cable though.
Any other suggestions?
2000 Subaru OBS
Dell P3 @ 900 Mhz
80GB External HD
Old 03-30-2004, 08:46 PM   #4
it's connected like this right?
into monitor: round 7 pin adapter
into laptop: touchscreen USB and VGA adapter
the USB is just the touch screen. You do have both plugged into the laptop right?
I made even stupider mistakes when I did mine so that's why I'm asking -- I plugged the touch screen USB into the composite output USB port on the monitor itself instead of into the laptop's USB port.
Edit: Reading your post again it doesn't look like you made any mistakes like that, but how does the VGA cable reach and the USB doesn't? (you didn't mention having to get a vga extension)
NS98GSR is offline   Reply With Quote
Old 03-31-2004, 02:24 AM   #5
try a usb booster cable but at such a short run your cable is probably bad
port20 is offline   Reply With Quote
Lilliput - linux supports usb touch screen? chenko LCD/Display 9 10-03-2004 06:58 PM
Lilliput USB cable Custommx3 LCD/Display 2 03-20-2004 07:12 AM
Lilliput USB and VGA connections FunkDaMonkMan LCD/Display 1 01-01-2004 09:32 PM
USB extension az1324 General Hardware Discussion 5 12-15-2002 12:14 PM
longest usb extension zx3chris General Hardware Discussion 5 09-30-2002 02:39 AM
