Quote: Originally Posted by CdRsKuLL
you can apply power via the 12v socket on the side, or via the phono rca / usb connecter thats included with the lilliput. I noticed after taking one apart and seeing what was what, when I put it back together, it didnt work !! it seems the ribbon cable that plugs into the buttons has a little bit of play in it. Play as in it doesnt line up unless you position the cable dead in the middle of the slot, if its slightly to one side its a non worker. I know this would mean invalidating your warranty. I would be tempted to return it, unless you feel lucky
eTard - the exact same thing happened to me when I was fiddling around with my screen - it refused to power on after I re-connected the cable to the button board. I disconnected and reconnected it and that solved the problem. Try CdRsKuLL's suggestion before returning the screen (if voiding the warranty is ok with you).
