Old 04-03-2004, 12:08 AM   #1
Nav_Attack is on a distinguished road
vga -> composite -> vga (possible?)
i was wondering if it was possible to convert VGA to composite and then back to VGA.. reason being i've got a composite input LCD now, but needless to say the resolution sucks ***, and im looking into getting a VGA screen. I've already got the cable laid well for the composite wire, and would rather not re-lay vga cable. i doubt its likely, but i'm holding on to a slim, slim, fading hope.
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
Nav_Attack is offline   Reply With Quote
Old 04-03-2004, 12:15 AM   #2
Bobby Digital is on a distinguished road
Even if it were possible (I'm not sure), you definately wouldn't get the quality of a VGA screen so having one would be pretty much pointless. You'll be better off to lay some VGA cable all the way.
Bobby Digital is offline   Reply With Quote
Old 04-03-2004, 12:18 AM   #3
i figured (sigh). don't know whats worse --- getting the system up and running in the first place or wanting to upgrade it within 15 mins of getting it up.
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
Old 04-03-2004, 12:26 AM   #4
Almost a Ghost is on a distinguished road
It is possible, but it's like taking a 640x480 image resizing it to 320x240 and then resizing it to 640x480.
Almost a Ghost is offline   Reply With Quote
Old 04-03-2004, 01:50 AM   #5
hehe. so essentially, its ugly?
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
Old 04-03-2004, 12:26 PM   #6
Registered User
gork's Avatar
gork
It would also be pretty expensive.
You can convert VGA to NTSC with many devices out there; the problem is that you lose a lot of the resolution when you do it. NTSC specifies only 525 lines of total resolution and generally only 480 are visible. The idea of "resolution" is dependent on many other things including how the signal is carried to a monitor (component Y,Pb,Pr/s-video/composite, etc), but needless to say, even if you did get a very good vga scan converter, the best you'd ever be able to reconstruct from an NTSC picture is probably 640x480
And that's just the image resolution problem. NTSC can't show as many colors as VGA. The color gamut is smaller. Here's an example:
The colors on the TOP row are the brightest hues that VGA can manage. The colors on the bottom row are the brightest hues that NTSC can encode. A lot of TV's perform gamut-expansion to make the colors appear less dull, but unless you get a very expensive upscan converter to convert NTSC back to VGA you probably won't get this benefit and, so, you'll lose some color information also. (As an aside, you can see that blue is the brightest color that NTSC can show. That is why most electronics blank the screen to blue!)
Still, if for some reason you need to do it, I'd recommend using a Cheese Video Box as the lowest cost NTSC->VGA upscan converter out there right now..
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 04-03-2004, 12:38 PM   #7
beaverpants is on a distinguished road
vary ugly
beaverpants is offline   Reply With Quote
vga to composite or vice versa ? slasherx LCD/Display 14 03-05-2004 06:53 PM
uTV-2000 - VGA to Composite - Opinion? curtkay General Hardware Discussion 2 02-12-2004 12:32 PM
7" composite or 15" true vga lcd? cdm LCD/Display 3 11-26-2003 02:45 PM
FS. VGA to TV (composite and s-VHS) converters. Casper Classified Archive 0 08-13-2002 05:33 PM
composite -> vga mp3z24 LCD/Display 4 03-26-2002 10:56 AM
