Old 04-07-2004, 07:09 PM   #1
Extend lilliput ribbon connector?
Does anyplace on the internet or anywhere sell a ribbon cable that is the same pin number and connection style of the lilliput 7" control panel? Basically I am looking to mount the control panel somewhere else with custom buttons, but i need a longer ribbon cable. anyone know?
nick9871 is offline   Reply With Quote
Old 04-07-2004, 07:14 PM   #2
a vga extension and usb extension wont work for you?
Bama5150 is offline   Reply With Quote
Old 04-07-2004, 07:16 PM   #3
no no no. The screen is cusom mounted in my dash. However i didnt like the buttons showing, so the front panel is just sort of dangling/taped to something behind the screen. I would like to be able to use the buttons however the ribbon connector that goes from the button control panel to the lilliput mainboard is very short, i want a longer one of those if possible.
Old 04-08-2004, 03:03 AM   #4
Zac
Extending the leads on the IR sensor is much easier if you would rather use a remote then all the buttons....otherwise good luck, its a 13-pin cable by Sumitomo. Mine is torn across 3 wires (unused wires luckly) and I also need to find a replacement soon.
I've done plenty of searching, but its 3am here and a little late to e-mail/call companies about getting a custom cable.
If you find a good source do share though :-P
Zac is offline   Reply With Quote
Old 04-08-2004, 03:15 AM   #5
Registered User
gork's Avatar
I doubt you will be easily able to find such a cable. They just aren't really manufactured to be that long.. Check with Digi-Key or Mouser .. they are the two best places that you could get a single cable if it exists.
If it doesn't exist (and it probably doesn't) your best bet might be to wire external buttons of your own to the button contacts on the lilliput board. The buttons all use a common ground, so it wouldn't be any more wires than is in the ribbon cable. You could get some of that multi-conductor wire to keep it all neat and tidy.
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 04-08-2004, 10:41 AM   #6
samc's Avatar
Am I missing something? bbasically you just want wires? check the lilliput ~~> indash pocket DIY and just extend your wires.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 04-08-2004, 11:33 AM   #7
hi
i have a longer ribbon on my display, i mailed a couple of companies that sells/makes this cabels and got a sampel from them .
The funny part is that its not the 13-pin in both ends, one of them is 14-pin (thats what they call quality !!!!)
i have one spare cabel but its 28-pin with 0,5 mm pitch, i misunderstod them when i talk to them. But it fits, its just that on pin takes to wires.
//Peter
mrzigzag is offline   Reply With Quote
Old 04-08-2004, 11:46 AM   #8
Aftaab001's Avatar
I couldn't be bothered to look for an IDE flat extension cable so i cut the ribbon cable halfway and used normal printer cable to extend the control to a metre roughly. check my link underneath.
My project is also there
http://uk.f2.pg.photos.yahoo.com/ph/...&.dnm=6143.jpg
Aftaab001 is offline   Reply With Quote
Old 04-08-2004, 01:30 PM   #9
Registered User
gork's Avatar
Wow did you completely coat the entire backside of your screen with hot glue?
MY CAR IS FOR SALE!
Old 04-08-2004, 01:39 PM   #10
Using remote would be great. Is there a writeup somewhere on how to move the IR sensor or should i just search? Can you power on the screen via the remote? thereby making it not necessary to modify the sceen to power up automaticaly (like Mastero did)
Old 04-08-2004, 04:29 PM   #11
im confused, i thought i read that the newest lilliputs powered up automatically without any mods.
robr is offline   Reply With Quote
Old 04-08-2004, 05:48 PM   #12
Zac
Nick: I did this to mine yesterday, and it came out pretty good...my camera sucks, so no good pics of it...and yes, all of the buttons on the screen are accessable thru the remote.
-Take the button pad out of the case, unconnect, ect...
-Bend the IR sensor so its perpendicular to the board.
-Gently grab the sensor with pliers and heat up the connections on the other side with a soldering gun....wiggle the sensor around as you do this and get it free from the board.
-Get some wire - I used part of an old IDE cable.
-Strip the ends and then heat the holes up on the board and get the wires in there where the sensor's pins were. (I didn't need extra solder, you may though.)
-Trim off any extra wire sticking through on the other side of the board.
-Solder the wires to the sensor....to protect them from shorting I coated them in some random expoy lying around....you can use tape/whatever though.
And - auto poweron by coyote (I'm sure youve seen it, but while youve got the case open.... :P)
http://www.mp3car.com/vbulletin/lcd-display/24047-my-solution-auto-power-lilliput-screen.html
Old 04-08-2004, 07:03 PM   #13
ribbon cable
Hey Nick9871,
check this site out...
diyAudio.com
goto--video forum
thread name is--ribbons cable on page 3
I hope this helps, if this is what your talking about?...
lesko
lesko is offline   Reply With Quote
Old 04-08-2004, 09:05 PM   #14
Aftaab001's Avatar
Talking
No it's cling film, just for temporary precaution when working on the sceen.
I'm sorry if i've ruined the joke
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Finally got the infamous lilliput Jurassic Park logo masch LCD/Display 37 08-06-2004 04:23 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput USB-->Video connector rewire question. russ LCD/Display 0 02-17-2004 07:10 PM
name of ribbon connector? etrik General Hardware Discussion 1 08-12-2001 12:49 AM
