Old 04-14-2004, 11:42 PM   #1
Wild Violence is on a distinguished road
Question Precautions in wiring up an LCD?
I'll be receiving an LCD screen I've bought in a couple of weeks, and I'd like to know what precautions I should take to make sure I don't destroy it as I experiment with hook ups (I've read a few posts here where people mention blowing their LCD modules).
The particular unit I've bought is here...
http://www.lcdspecifications.com/nec...6448AC2006.pdf
...If that helps.
What I had envisioned was having a cable running from my VGA output, with each pin segregated to a terminal on a solderless breadboard. The input pins for the LCD would be likewise segregated to terminals on the opposite side of the breadboard. I'd then experiment by connecting the VGA terminals to the appropriate LCD terminals. The LCD power requirements are all 5V, so I was going to simply connect all such terminals to the 5 volt rail of a computer power supply. Does this sound like an appropriate method, or I'm going to end up with a pile of slag?
As a general question, are there any "LCD screens for dummies" guides or sites worth reccomending?
Wild Violence is offline   Reply With Quote
Advertisement Sponsored links
Old 04-15-2004, 02:49 AM   #2
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
Looks like you'll need a controller card for that LCD - the interface is digital according to the section entitled "Interface pin connection" and the "General specifications" in the PDF you posted.
So the first precaution you'll need is to acquire such a controller card, you can't just connect it to a VGA port.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 04-15-2004, 04:57 AM   #3
That figures...
Any sources for those that you'd recommend?
The screen is also coming with another module, labelled a 'high voltage module' (see attached image). Would that be considered the power inverter?
Old 05-12-2004, 03:53 PM   #4
JoyRidun's Avatar
JoyRidun is on a distinguished road
yes that would be the power inverter. be very careful with that if u dont wana die or seriously injur urself :d
JoyRidun is offline   Reply With Quote
notebook LCD 2 standart VGA input wiring valiokaz General Hardware Discussion 2 06-06-2002 11:53 AM
LCD wiring help mprover LCD/Display 3 01-02-2002 02:07 PM
datalux 4x20 red lcd wiring diagram? etrik LCD/Display 0 12-07-2001 04:35 PM
HELP wiring 31pin LCD to SCSI cable! Squeeky LCD/Display 4 06-25-2001 07:56 AM
I need some help with wiring an LCD lstrunk LCD/Display 2 05-02-2001 04:01 AM
