i didn't look to c how fast and whatnot the mobo is you blew out, however, the board i use has a tft lcd connector on it. i'm using an lcd right now that is pin for pin compatible w/ the nec display you have. also, i'd seriously doubt u'd be able 2 drive that lcd off the parallel port and expect to be able to use all 256k colors. anyways, the board i have is an arcom sbc-gxm embedded board. it runs entirely off 5v, and draws about 1A w/ full cpu usage (i'm not including the LCD inverter power consumption here). it's only got a cyrix media gx (AMD/national geode) runnin @ 233mhz. so...its kinda slow, and u won't be able 2 play movies on it. but its still pretty sweet cause its got a touchscreen controller built on, pc104, and pc104 plus bus on it (ISA and PCI busses). there were a bunch of those boards on ebay, but who knows if they're still there or not. the board supposedly supports a number of different displays, but u need different bioses which arcon doesn't seem 2 wanna give out if u don't buy the board from them. oh well, ur display is natively supported. the only trouble u'll have is finding a mating connector for their retarted lcd connector. that connector isn't made anymore, and the replacement one isn't stocked by mouser, digikey, or allied electronics. i don't think newark had it either. i hacked the connector to accept a 68pin scsi connector. what fun. so ya i hope this helps ya some. andy
