Quote: Originally Posted by j81bird
Yes the usb is for the touch screen if you do not use it no touch screen : (
He's talking about the "USB" port on the side of the Lilliput case itself. It's not actually USB, they just used that probably because it fit, was cheap, and had the right number of pins. It's actually an analog breakout port that has the composite video, sound, and even power (it appears) so that if you want, you can run power from far away without needing to run a seperate power cable. If that's not correct, I'm sure someone will chime in.
