10-22-2006, 09:43 AM
#61
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Vehicle: 98 Cobra Convertible | 2004 4Runner SR5 V8 4WD
Not sure if this will help for what you're looking for, but the main driver page for lilliput monitors is here:
http://www.lilliput.com.cn/eng/service.asp
/edit, it should be, because if you follow their product page for your monitor to the downloads it takes you to the same page.
Good luck.  Cheers
10-22-2006, 09:49 AM
#62
One more thing... if you download the drivers from there, the file names are like "2005917135317.0" just rename it to "2005917135317.0.zip" and winrar will open it just fine (probably winzip too)
10-22-2006, 04:41 PM
#63
Thanks guys.
Unfortunately the driver there is not working (I think b/c com port conflict with GPS) Anyway I found this site here
http://cartft.com/support/drivers/TFT/tftdrivers/
I don't know if it will solve my problem, but they certainly have a cornucopia of drivers there. The one from egalaxy worked for me before and I thought it was saved somewhere, but apparently I lost it. (Although it could have been a fluke that it worked.)
11-07-2006, 10:39 PM
#64
Vehicle: AVUS M3
what is the best way to connect a lilliput to a laptop with the seperate monitor settings? I have no idea whats going on. whenever I try to seperate the connection i get the same display as i do on my dell inspiron 5100. I was somehow able to get the lilli in 800 X 600 resolution, but the screen would move around. Can anyone help me?
CLICK ME FOR BMW CARPUTERS
95 Avus M3
Mods: ;-)
Carputer: Lilliput 619, GPS= LT-20 Receiver, IGuidance 3 & Streets & Atlas 2K6, RR Front End, Removable Dell Inspiron Laptop, More to come........
11-15-2006, 11:58 AM
#65
Can you make the lilliput waterproof?
Andrew Hurley
Clemson University - Packaging Science
1964 1/2 Mustang Coupe
RestoMod
http://members.cardomain.com/rhurley
11-15-2006, 12:12 PM
#66
Confusion Master
Vehicle: 1997 BMW E36 328I
It would have to be in a fully enclosed container, then there would be an issue of heat, the backlight can give off a lot of heat after being on for awhile. and if you don't get rid of that heat it will fail.
11-15-2006, 12:14 PM
#67
does the "touch screen" feature have to be on the screen itself? I could enclose the screen inside the dash and vent it well, then have the touch screen on the outside of some plexi? Can the touch screen film (??) be exposed to direct water?
Andrew Hurley
RestoMod
11-16-2006, 01:43 PM
#68
Vehicle: AVUS M3
95 Avus M3
Mods: ;-)
11-26-2006, 12:22 PM
#69
Vehicle: 99 Trans Am
Here are the true viewing angles for the 10.4" Lilliput FA1042-NP/C/T based on my real world experience.
Note, this is contradictory to what the specs say as they rate it with a wider verticle viewing angle than it actually has. Hopefully this will save someone else time and money by not choosing the wrong screen for their application.
02-05-2007, 04:47 PM
#70
Vehicle: 2001 Mazda Millenia
Eby 701
Can anyone help? I have the EBY 701 and I tried programming the auto power funtion that I saw somewhere in this thread. And when I input the "588998" code, the menu for languages come up.
And the screen would take no more inputs. After a few seconds the language menus disappears.
I have powered it off and on to see if there would be a miracle, but......NAH!
Someone help pls.
02-05-2007, 05:19 PM
#71
NEVER MIND peoples....I found what I was looking for.
I entered the code "588998" and pushed the menu button and it gave me options. ANd i made necessary changes.
Thanx for looking tho'. LOL
02-09-2007, 10:53 AM
#72
Due to the way touchscreens/pads work, if you get water on them they will not work until they dry out. If you are planning to get it wet then you are gonna need to use buttons instead.
02-24-2007, 09:19 PM
#73
Drivers link is broken. Here its a update link. http://www.eeti.com.tw/web20/eg/drivers.htm
Voche list: Migel628, Bugbyte, Defiler, Kingsdude, über
03-01-2007, 01:35 PM
#74
Vehicle: 2004 GMC Denali Yukon
DOes anyone know if any of the new Lilliputs offer rear cam support like the Xenarcs'??? In other words, if I wire the backup cam to the reverse light, will the monitor switch to AV1/2 ??? Please help as I searched a bit.
03-12-2007, 06:23 PM
#75
I was wondering about this myself... any knows?
| Thread Tools |
| Display Modes |
Linear Mode
