Old 06-05-2007, 09:37 PM   #76
JasonWW is on a distinguished road
I tried that. It's better, but you loose some contrast. The black areas look a little more grayish.
If your vid card has an option to flip the image it should perform the same. It doesn't take more power to run it upside down.
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How to tune your sound system
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
JasonWW is offline   Reply With Quote
Old 06-17-2007, 12:27 PM   #77
stealinfool's Avatar
stealinfool is on a distinguished road
link needs updated
Please update the driver link.. http://www.eeti.com.tw/web20/eg/drivers.htm
no longer egalax it seems.
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 08-25-2007, 01:19 AM   #78
Snortonnorton is an unknown quantity at this point
Proper refresh rate for 629/619
found out after much anguish that you have to have xp running at 75 or less refresh rate in your diplay/monitor properties for the lilliput 629 to post windows display.
(if you see your bios start up but windows is blank, then you probably have to change refresh down)
my specs were........ xp pro service pack 2 on an old tnt2 video card.
the 619 should need the same thing as the 629. 75 or less refresh rate.
at 85, my lilliput would not post windows. if you go too low, you might get flickering.
Snortonnorton is offline   Reply With Quote
Old 09-14-2007, 06:52 AM   #79
flibble is an unknown quantity at this point
For any Linux users, egalax has released a new X driver which is far superior to the evtouch one (even has a control applet which is a copy of the windows one )
http://www.eeti.com.tw/web20/drivers...06.0704.tar.gz
flibble is offline   Reply With Quote
Old 09-30-2007, 07:51 PM   #80
underwaterdan is an unknown quantity at this point
Can someone update the images on the measurements of the 7" lilli - the image doesn't seem to load
Project Page - 1993 Wrangler Jeeputer
Progress Meter {**-------} 15% most of the parts are in or have been ordered... Assembly has begun!!!!
underwaterdan is offline   Reply With Quote
Old 10-09-2007, 01:01 PM   #81
effyzaz is an unknown quantity at this point
Hi - how do lilputs rate compare to the shark 10.4?
http://www.mp3car.com/vbulletin/lcd-...lcd-215-a.html
effyzaz is offline   Reply With Quote
Old 11-30-2007, 06:24 PM   #82
20AE2306 is an unknown quantity at this point
Re: LVDS?
There are several companies out there making boards like this:
http://jiniershop.com/index.php?sale...no=326&otype=6
If you look through their supported displays, the 7" hitachi used in these lilliput's is listed. What else would be required to connect it directly to a NX15000G motherboard with LVDS? Specs for that are here:
http://www.idotpc.com/thestore/pc/vi...&idproduct=482
Unfortunately I haven't been able to figure out how to ask the manufacturer this question directly, I'm not sure where they have their resellers listed nor anyone else associated who may speak english...
I found that first board via Google, there was a discussion in a forum topic here (search for "TX18D16VM1CAA" on that page):
http://pc4car.com/bbs/zboard.php?id=...c=desc&no=1781
Here's another board:
http://www.ieiworld.com/files/ieinet..._datasheet.pdf
And another:
http://www.evalue-tech.com/products/...530_Series.cfm
Those two don't list the 7" Hitachi as a supported display.
Apparently there is a slightly better spec version of the 7" Hitachi now available, and it is also supported by the first two cards:
http://www.hedus.com/sales/part_sear...=TX18D16VM1CAA
Anyone been able to do this yet? I've spent way too much time combing through forum posts and I have yet to find anyone who was able to plug-and-play a 7" LCD of any kind via LVDS even with one of these boards.
20AE2306 is offline   Reply With Quote
Old 12-01-2007, 09:21 PM   #83
LAME :)
lopan's Avatar
lopan is on a distinguished road
I just got my Hirose connectors and crimp connectors from Digikey to make a cable for my 6.3 inch NEC panel and connect it to my onboard LVDS controller.
My question is with these boards, it only says "24 bit LVDS Transmitter / Receiver Module" is this taking TFT and processing it to LVDS??? If so that'd be friggin awesome... The panel you've listed is TFT, which ALL of the 7" screens I've seen are. I managed to find a 6.3 inch LVDS screen off ebay for 70 bucks... but I'f I could use one of these to convert the signal it would be well worth looking into.
I'm hoping as you said the lilli panels are listed that it does convert... If so, all you'd need is the following.
Cable from the panel to the LVDS Transmitter
Cable from the transmitter to the LVDS connection on the mobo (or daughtercard)
Backlight coverter
Cable from converter to mobo (or daughtercard)
The connectors and crimp connectors are cheap but the crimpers are very pricey... I'd love to find a place that sold these cables on the cheap, if anyone has sources please share.
lopan is offline   Reply With Quote
Old 01-05-2008, 02:47 PM   #84
agniusm's Avatar
agniusm is an unknown quantity at this point
In-dash lilliput
How to read lilliput in-dash screen motors:
If the motor rattles it is most likely that the gear axle in gearbox is bent and gears are skiping.
agniusm is offline   Reply With Quote
Old 01-16-2008, 10:30 PM   #85
Firebird2 is an unknown quantity at this point
If all else fails try this link
http://210.64.17.162/web20/eg/drivers.htm
Firebird2 is offline   Reply With Quote
Old 01-17-2008, 12:31 AM   #86
galvitron's Avatar
galvitron is an unknown quantity at this point
800X480 on Lilli 619
This is out of left field but I thought it belonged here...
For those people who are modifying the ini file for their Intel onboard graphics drivers to display 800X480 here is the DTD string I used. The first numbers are the refresh rate and you may have to tweak those...
4C 1D 20 FC 30 E0 14 10 20 38 37 00 00 00 00 00 00 1E
Also, here is a driver that works at 800X480 and my Lilli 619 on an Intel G965 series motherboard:
http://www.mp3car.com/vbulletin/atta..._0_windows.zip
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 02-14-2008, 09:28 PM   #87
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
OK got my 2008 Lilliput 629 today, must say it is awsome. Did the reprogramming mod and I couldnt be happier.
Bright, oh yeah.
In sunlight, no problem. Really. I was using a 7" phylon/t-view and sunlight killed it prety much. Now it is like night and day. Not the transreflective either. Couldnt even imagine how good that must be.
Just thought I would tap in with my comments on the new screen.
One happy camper....
ThunderStick is offline   Reply With Quote
Old 02-16-2008, 12:02 PM   #88
disc0monkey is an unknown quantity at this point
hey guys trying to get my auto-on working all i have is a PC mode, av1 av2. no vga mode? what can i do/
disc0monkey is offline   Reply With Quote
Old 03-04-2008, 10:43 PM   #89
eclipseboi87's Avatar
eclipseboi87 is an unknown quantity at this point
LCD Ribbon Replacement?
Hey guys got a question, I have a lilliput touch screen monitor and the LCD Ribbon cable has gone bad. I need a replacement and quick. I cheked digitalww.com and they are sold out. where can I pick up a new one from and if any of you are selling one could you please let me know......
eclipseboi87 is offline   Reply With Quote
Old 03-05-2008, 08:01 AM   #90
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
mouser.com
http://www.mouser.com/Search/Product...538-21020-0438
Enforcer is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 09:12 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
