03-14-2008, 06:13 PM
#92
Sheepdog
Lilliput 10.4 Wiring -- How the Touchscreen Wires Connect
If you've uncased your Lilliput 10.4", Model 1042, I could use some help. In disassembling mine, I accidentally (violently) detached the four small wires that appear to be for the touchscreen. They look undamaged. There are two yellow wires and two black wires. I need to reassemble the plug they go into, and wonder if anyone can tell me which wire goes where. Here's a picture of the wires -- in order as they come off the board -- plus the two plug components, plus the board they plug into.
Click on the image to enlarge it.
EDIT: I got this answer elsewhere in the LCD/Display forum, so I've included it here in the FAQ:
Quote: Originally Posted by GiODi
Ha... i did the same thing with my first lilliput. I'm pretty sure they go in the order that you have it there. I don't think it matter too much anyway because it would correct itself in calibration.
Thanks, GiODi. I'll just hook it up as pictured and test it out.
Reason: Added information
03-15-2008, 10:11 AM
#93
Auto switch feature in some new Lilliput screens
I think it is very important info and it deserve to be placed here. It seems that some new 2008 lilliputs have auto switch feature, which is very useful when you have for example rear view camera.  This feature can be simply activated in menu. But it is not clear why some of new 2008 screens have this feature while the others don't... The subject definitely needs some more investigation. More info can be found here:
http://www.mp3car.com/vbulletin/lcd-...lilliputs.html
03-22-2008, 12:15 AM
#94
Hey.
I was working on my CarPC project and I accidentally put pressure on one of the components of the main board of the Lilliput. I need to figure out what to replace it with. Trouble is that I moved in the meantime and I can't find the actual broken piece, but hopefully someone can tell me based on the images below. The missing part was an inductor, the bottom of which is still attached to the board.
Any info would be appreciated. The part is labeled 2L06.
It looked like this:
Anyone know the specs for it or some idea of what to replace it with?
03-26-2008, 01:02 AM
#95
Anyone know where to find gears for the gl701?
THanks!
03-26-2008, 06:49 PM
#96
does any1 have his model 889GL-80NP/C/T
04-02-2008, 12:28 AM
#97
Anyone know what the specs are for the inductor labeled 2L06 on the 619 main board? I posted about this a week ago, both here and in a separate topic and nobody has replied at all. Can someone who has the board please take a close-up pic so I can print it out and take it to some electronic shops? I mean unless of course someone can tell me exactly what the part is and what it's specs are.
04-14-2008, 02:31 AM
#98
I posted this a while back without any answer, so I'll try again.
Does anyone know how to fix an inverted x axis on the touchscreen? A fellow forumite said by using XP and the touchkit drivers he fixed his problem, but I'm still having the same issue.
Any help would be AWESOME
04-14-2008, 03:32 AM
#99
Seriously, does anyone not have their display cracked open that they could just post a pic of that component at 2L06? It may be identifyable from that, I need something to go on here to fix my display.
04-16-2008, 07:21 AM
#100
Just thought i would let you all know that i have found a place that stocks the 1.5a fuses inside the lilliputs
http://cpc.farnell.com/jsp/search/br...equestid=63935
its the top 1 on this link.
Prepping for Trax in september
Re-Building the whole CarPC to upgrade all the software
Whole new boot build and moulding my screen into the dash...Again
04-17-2008, 01:36 AM
#101
Finally fixed it.
The 5.0.0.23 drivers were the issue. I downloaded the ones off the Lilliput UK site and they worked without an issue.
06-05-2008, 02:14 AM
#102
Pinout for the newer 10-pin DIN plug:
[1][2] [3]
[4][5][6][7]
[8][9][10]
Note: Colors may differ! These colors represent the color coming from my Lilli's controller board (not the VGA/USB plug).
[1] - Yellow - VGA pin 2 (Green)
[2] - Shield - Goes to USB shield
[3] - White - VGA pin 3 (Blue)
[4] - Orange - USB pin 1 (+5V)
[5] - Green - USB pin 2 (D-)
[6] - Brown - USB pin 3 (D+)
[7] - Black - USB pin 4 (GND)
[8] - Blue - VGA pin 13 (H-sync)
[9] - Red - VGA pin 1 (Red)
[10] - Purple - VGA pin 14 (V-sync)
It says on my controller board 619-68521. I am guessing this is a model number? The LCD says Hitachi TX18D11VM1CAA.
I used one of these to make a new VGA cable without the DIN plug:
http://www.btx.com/Categories.aspx?C...5-65bfe2be344f
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
07-16-2008, 06:16 PM
#103
Some timing info for those trying to get 800X480 on the 7" Lillis:
Mine:
PixelClock, 32143
HorzActive, 800
HorzSync, 32
HorzSyncPulse, 56
HorzBlank, 252
VertActive, 480
VertSync, 3
VertSyncPulse, 7
VertBlank, 20
Flags, 0x20000
Someone else's:
Quote: Originally Posted by psyrex
PixelClock 38400 <-- this will give you 73Hz refresh. You can try playing around and to get close to 75Hz, but I didn't feel it was as stable as this number, which displays fine
HorzActive 800
HorzSync 32
HorzSyncPulse 56
HorzBorder 0
HorzBlank 252
HorzSize 25
VertActive 480
VertSync 3
VertSyncPulse 7
VertBorder 0
VertBlank 20
VertSize 16
Again, this is for the 7" widescreen 800x480. These numbers are a combination of powerstrip's settings and some stuff I found on this site.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
07-29-2008, 04:08 PM
#104
bad link to lilli drivers "page not found" for any of the drivers, darn it!
08-15-2008, 04:38 PM
#105
Eby701-np/c/t
Hey there guys I wanna get this monitor
EBY701-NP/C/T
Found it http://cgi.ebay.com/Lilliput-EBY701-...QQcmdZViewItem
I would like to know if anyone has the measurements for the whole housing
and then just the screen componets. I want to make a custom bezel for it?
i can't find any measurements if it ment my life! It would be awesome if someone could just help me or just push me in the right direction for this information!
-Charles-
| Thread Tools |
| Display Modes |
Linear Mode
