Go Back   MP3Car.com > Mp3Car Technical Hardware > LCD/Display
Old 09-18-2008, 11:57 AM   #106
jessekilner's Avatar
jessekilner is an unknown quantity at this point
Iv'e been searching for awhile I have the 10.4 lilliput.. It DID'nt come with the car adaptor only the AC one.. strange but either way I don't want to run a Inverter 110V. it says 12V 1200mah..output . I understand the wiring to the ignition but is'nt the amps from a car battery alot more than the .06A max input it requires? Im running this off a P4 laptop so no MX/ATX PSU. I plan on using a regulator but what do I need to adjust the amps down or is this not required.. all the forums I see here are targeted toward the ciggerette adaptor cutting and running to the ignition or psu but are they still using the inverter that came on the car plug, and only changing where it's wired too or can it really be wired directly to a 12v-30Amp line without inverter thats on the ciggerette adaptor?
jessekilner is offline   Reply With Quote
Old 10-05-2008, 06:47 PM   #107
NaMeLeS5 is an unknown quantity at this point
I have a problem with my BlaXtream TC1000
THe front buttons on my BlaXtream TC1000 liliput don't work... they used to work now they don't work at all...i need some help plzz..
When i put a cd or dvd in ..the unit autoplays the cd/dvd ..and when i want to change,stop,.. the track/song ..the button doesn't work..
NaMeLeS5 is offline   Reply With Quote
Old 10-08-2008, 05:37 PM   #108
bfb314159265 is an unknown quantity at this point
Lilliput with Mac
I got my Lilliput screen today and I installed the right drivers for my computer. However, for some reason the screen is not detected by my computers when I open TouchKit. Are there any specific cables I should be using to get the Lilliput to my Mac, or am I just missing something?
bfb314159265 is offline   Reply With Quote
Old 10-20-2008, 09:04 PM   #109
Kevin22 is on a distinguished road
digitalww is password protected? cant view the site anymore.. looking for a place to buy a replacement ribbon
Kevin22 is online now   Reply With Quote
Old 10-22-2008, 06:17 PM   #110
Foggin331's Avatar
Foggin331 is an unknown quantity at this point
http://www.digitalww.com/ needs a user name and password to fuction. Is there anyone with pics of lilliput disassembly I will be puting it into a 2006 f150. Also any install pics or links would be great.
Foggin331 is offline   Reply With Quote
Old 11-03-2008, 08:00 PM   #111
cherrybomb's Avatar
cherrybomb is on a distinguished road
I shoulda just come here to get the pinouts I needed, but I wound up finding my own solution, and blogged about it.
Here are my findings on wire colors and pinouts for the proprietary 9 conductor cable.
'99 Ford Explorer Eddie Bauer
CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
CarPC Project Web Site
SpaceNavigatorDriver SourceForge Project
Check out my blog.
cherrybomb is offline   Reply With Quote
Old 11-06-2008, 06:05 PM   #112
olkainry is on a distinguished road
in dash
I bought you a DWW-7VGT non motorized indash a few year ago.
I have a trouble with it.
I can not close the monitor anymore.
Seems like the big spring is not at the right place.
Could you please tell me how to do?
I remerber that on digitalww web site a procedure explained how to built a indash. does somebody has it?
thanks
olkainry is offline   Reply With Quote
Old 12-22-2008, 09:02 AM   #113
Thelgord's Avatar
Thelgord is an unknown quantity at this point
There seems to be a lot of broken links and digitalww is password protected. Can anyone fix this?
CarPuter
Planning....[||||||||||]60%
Parts.......[||||||||||]20%
Construction[||||||||||]0%
Software....[||||||||||]0%
Thelgord is offline   Reply With Quote
Old 01-20-2009, 02:45 AM   #114
zxylon is an unknown quantity at this point
Anyone cracked open an 8" touch screen? Mine's open and I cut the main harness that goes to the usb and vga out and soldered it to the board. I pinned it out and made sure to double check it but I'm not getting any signal from my computer. If there's anyone with one cracked open but still using the same connector to the board could you please get a pinout for the vga/usb to the main board? I know I just need the h-sync, v-sync, red, green, blue and the four pins that go to the usb connector. Here's a picture if it helps any. Any ideas??
zxylon is offline   Reply With Quote
Old 10-21-2009, 10:36 AM   #115
sxott is on a distinguished road
Youguys haven't put the codes in the Faq for autoturn on and such?
5 8 8 9 9 8 for eby701
My Install
sxott is offline   Reply With Quote
Old 10-26-2009, 04:33 PM   #116
jr4284 will become famous soon enough
Detail drawing of the Lilliput 629, courtesy of John at Lilliput Electronics:
Edit: the 94.9 (Display Center) dimension should read: 84.9 (Display Center)
jr4284 is offline   Reply With Quote
Old 04-07-2010, 08:17 PM   #117
chris350's Avatar
chris350 is an unknown quantity at this point
does the lilliput 629 have an auto video switching mode? so if I were to add a rear view camera and when i put the car into reverse ..can the video switch automaticly? i swear i heard this before..
CarPc
Project "Driver"
Planning [99.9%]
Parts Collected [98.5%]
Installation & Fabrication [98%]
Total Completion Level [96.9 %]
http://www.mp3car.com/vbulletin/work...ct-driver.html
chris350 is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 03:58 AM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 06:58 PM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 08:12 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
