Old 03-26-2008, 01:02 AM   #106
Anyone know where to find gears for the gl701?
THanks!
rock99rock is offline   Reply With Quote
Old 03-26-2008, 06:49 PM   #107
does any1 have his model 889GL-80NP/C/T
shot598 is offline   Reply With Quote
Old 04-02-2008, 12:28 AM   #108
Anyone know what the specs are for the inductor labeled 2L06 on the 619 main board? I posted about this a week ago, both here and in a separate topic and nobody has replied at all. Can someone who has the board please take a close-up pic so I can print it out and take it to some electronic shops? I mean unless of course someone can tell me exactly what the part is and what it's specs are.
20AE2306 is offline   Reply With Quote
Old 04-14-2008, 02:31 AM   #109
ContaiN's Avatar
I posted this a while back without any answer, so I'll try again.
Does anyone know how to fix an inverted x axis on the touchscreen? A fellow forumite said by using XP and the touchkit drivers he fixed his problem, but I'm still having the same issue.
Any help would be AWESOME
ContaiN is offline   Reply With Quote
Old 04-14-2008, 03:32 AM   #110
Seriously, does anyone not have their display cracked open that they could just post a pic of that component at 2L06? It may be identifyable from that, I need something to go on here to fix my display.
Old 04-16-2008, 07:21 AM   #111
KennyKen's Avatar
Just thought i would let you all know that i have found a place that stocks the 1.5a fuses inside the lilliputs
http://cpc.farnell.com/jsp/search/br...equestid=63935
its the top 1 on this link.
Prepping for Trax in september
Re-Building the whole CarPC to upgrade all the software
Whole new boot build and moulding my screen into the dash...Again
KennyKen is offline   Reply With Quote
Old 04-17-2008, 01:36 AM   #112
ContaiN's Avatar
Finally fixed it.
The 5.0.0.23 drivers were the issue. I downloaded the ones off the Lilliput UK site and they worked without an issue.
Old 06-05-2008, 02:14 AM   #113
galvitron's Avatar
Pinout for the newer 10-pin DIN plug:
[1][2] [3]
[4][5][6][7]
[8][9][10]
Note: Colors may differ! These colors represent the color coming from my Lilli's controller board (not the VGA/USB plug).
[1] - Yellow - VGA pin 2 (Green)
[2] - Shield - Goes to USB shield
[3] - White - VGA pin 3 (Blue)
[4] - Orange - USB pin 1 (+5V)
[5] - Green - USB pin 2 (D-)
[6] - Brown - USB pin 3 (D+)
[7] - Black - USB pin 4 (GND)
[8] - Blue - VGA pin 13 (H-sync)
[9] - Red - VGA pin 1 (Red)
[10] - Purple - VGA pin 14 (V-sync)
It says on my controller board 619-68521. I am guessing this is a model number? The LCD says Hitachi TX18D11VM1CAA.
I used one of these to make a new VGA cable without the DIN plug:
http://www.btx.com/Categories.aspx?C...5-65bfe2be344f
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 07-16-2008, 06:16 PM   #114
galvitron's Avatar
Some timing info for those trying to get 800X480 on the 7" Lillis:
Mine:
PixelClock, 32143
HorzActive, 800
HorzSync, 32
HorzSyncPulse, 56
HorzBlank, 252
VertActive, 480
VertSync, 3
VertSyncPulse, 7
VertBlank, 20
Flags, 0x20000
Someone else's:
Quote: Originally Posted by psyrex
PixelClock 38400 <-- this will give you 73Hz refresh. You can try playing around and to get close to 75Hz, but I didn't feel it was as stable as this number, which displays fine
HorzActive 800
HorzSync 32
HorzSyncPulse 56
HorzBorder 0
HorzBlank 252
HorzSize 25
VertActive 480
VertSync 3
VertSyncPulse 7
VertBorder 0
VertBlank 20
VertSize 16
Again, this is for the 7" widescreen 800x480. These numbers are a combination of powerstrip's settings and some stuff I found on this site.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
Old 07-29-2008, 04:08 PM   #115
bad link to lilli drivers "page not found" for any of the drivers, darn it!
michaelgwynn is offline   Reply With Quote
Old 08-15-2008, 04:38 PM   #116
Eby701-np/c/t
Hey there guys I wanna get this monitor
EBY701-NP/C/T
Found it http://cgi.ebay.com/Lilliput-EBY701-...QQcmdZViewItem
I would like to know if anyone has the measurements for the whole housing
and then just the screen componets. I want to make a custom bezel for it?
i can't find any measurements if it ment my life! It would be awesome if someone could just help me or just push me in the right direction for this information!
-Charles-
Ringfinger69 is offline   Reply With Quote
Old 09-17-2008, 08:05 AM   #117
Nevermind
Cancel Measurement request
Got the 629GL-NP/C/T
Old 09-18-2008, 12:57 PM   #118
jessekilner's Avatar
Iv'e been searching for awhile I have the 10.4 lilliput.. It DID'nt come with the car adaptor only the AC one.. strange but either way I don't want to run a Inverter 110V. it says 12V 1200mah..output . I understand the wiring to the ignition but is'nt the amps from a car battery alot more than the .06A max input it requires? Im running this off a P4 laptop so no MX/ATX PSU. I plan on using a regulator but what do I need to adjust the amps down or is this not required.. all the forums I see here are targeted toward the ciggerette adaptor cutting and running to the ignition or psu but are they still using the inverter that came on the car plug, and only changing where it's wired too or can it really be wired directly to a 12v-30Amp line without inverter thats on the ciggerette adaptor?
jessekilner is offline   Reply With Quote
Old 10-05-2008, 07:47 PM   #119
I have a problem with my BlaXtream TC1000
THe front buttons on my BlaXtream TC1000 liliput don't work... they used to work now they don't work at all...i need some help plzz..
When i put a cd or dvd in ..the unit autoplays the cd/dvd ..and when i want to change,stop,.. the track/song ..the button doesn't work..
NaMeLeS5 is offline   Reply With Quote
Old 10-08-2008, 06:37 PM   #120
Lilliput with Mac
I got my Lilliput screen today and I installed the right drivers for my computer. However, for some reason the screen is not detected by my computers when I open TouchKit. Are there any specific cables I should be using to get the Lilliput to my Mac, or am I just missing something?
bfb314159265 is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 09:12 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
