Old 04-23-2004, 04:35 AM   #1
guvi's Avatar
Lilliput Over Range!?
Hey!
Once again a problem with my Lilliput 7"
Few days ago i had some problems with my PC (Epia-M, TravlaC134, 512MB, 40gB.... ), so i decided to install the system new.
ok, so far so good... the system runs! Yesterday i wanted to take back the PC in the car. But when i boot/start the computer, the lilliput shows only "OVER RANGE"
The graphic card runs 800x600 @ 60Hz. Before that also works.
So i took the PC once again out, to controll the settings on an other screen. 800x600@60Hz.... all correct. Bios-Settings of the Screen also 800x600 using CRT+TV
In the OSD of the Lilliput, theres the INFORMATION-Function of the Screen.
There i can see, that the Screen is running at 1600x1200
There the Signal comes from?
tia,
guvi
The Spanish Style...
SEAT LEON! My CARPC-Install or the thread up here
guvi is offline   Reply With Quote
Old 04-23-2004, 05:17 AM   #2
I had a similar problem also. Only OVERRANGE then only more NO SIGNAL. Tried out on different PC's, on which it before still functioned.... I sent back the display to digitalww and now i get a new one.
Regards
Oliver
http://picasso.zoffi.net
ozoffi is offline   Reply With Quote
Old 04-23-2004, 05:36 AM   #3
Raw Wave
Laidback's Avatar
Quote: Originally Posted by guvi
Hey!
tia,
guvi
Did you try a reset on the Lilliput?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 04-23-2004, 06:05 AM   #4
guvi's Avatar
I tried the reset!
just came back from the car. i tried the screen with a laptop. all works fine... the screen goes to 800x600
but when i connect the epia... OVERRANGE (screeninfo 1600x1200)
but the resolution on XP is still 800x600
Old 04-23-2004, 06:10 AM   #5
Raw Wave
Laidback's Avatar
So you get the 'Over range' message as soon as the car computer turns on, you don't even see the bios screen?
Laidback
Laidback Carputer
Old 04-23-2004, 06:33 AM   #6
Registered User
mpattonm's Avatar
Make sure you have "LCD" option selected in your Epia BIOS under the "Advanced chipset/Select display device" menu.
Let me know if it solved your problem.
mpattonm is offline   Reply With Quote
Old 04-23-2004, 07:14 AM   #7
guvi's Avatar
thats the problem. as soon i turn on the carputer, the lilliput shows "Overrange".
if the settings in winxp are to high... ok! but the bios i should see
>>Make sure you have "LCD" option selected in your Epia BIOS under the "Advanced >>chipset/Select display device" menu.
IŽll try to configure this setting in the bios.
Old 04-23-2004, 07:25 AM   #8
Registered User
mpattonm's Avatar
Definitelly do so. I believe it will solve your problem. of course to be able to do so you will need to hook up CRT temporarly.
Old 04-23-2004, 01:54 PM   #9
guvi's Avatar
yeah! you are right. the screen works fine again
now the old troubles with the TouchScreen are back!
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
Lilliput install in and Impreza, Lilliput issues SubPuter LCD/Display 76 04-19-2004 09:56 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
