Old 04-24-2004, 08:18 AM   #1
archimense's Avatar
Need help with Lilliput indash conversion
Hey everyone,
I'm in the middle of converting my Lilliput to use the digitalWW indash housing.
I've got a problem. I just wired all of the buttons from the board to the new button PCB and all of the buttons work except for the menu button. I can get into the menu using the remote, but not by pressing the button. The button has +5v when the button is not pressed, and 0v when it is pressed, which is what it is supposed to do.
Does anyone know anywhere else I could test for a short for this button? Or does anyone have an idea why the menu button would not work even though I detect the voltage change?
There isn't any loose solder on the board that I can see. The menu button did work before I started the conversion.
Thanks for any help.
archimense is offline   Reply With Quote
Old 04-24-2004, 04:08 PM   #2
archimense's Avatar
bump
Old 04-24-2004, 06:14 PM   #3
to long of a wire? so not all 5v are getting back?
beaverpants is offline   Reply With Quote
Old 04-24-2004, 06:18 PM   #4
archimense's Avatar
I tried measuring the voltage at the resistors that are on the board and it shows 5v there. So I don't think it has anything to do with not enough voltage getting to the chip. Not to mention that 0v signifies a button press so not enough voltage would mean the button is always pressed.
Old 04-24-2004, 06:47 PM   #5
Same thing happened to me. Seemed to be a bad switch for menu, so I use the V1/V2 switch as the menu button. But I put a different screen in there that only needed three buttons excluding the power button.
mestre is offline   Reply With Quote
Old 04-24-2004, 07:08 PM   #6
archimense's Avatar
I don't think this is a bad switch because the voltage across the switch changes just like the other switches do. But thanks for the suggestion.
Old 04-24-2004, 07:19 PM   #7
samc's Avatar
I can just tell you to have the screen open and press the button and see if you get a voltage across the pin5 and the ground.
http://www.digitalww.com/VGA_Lillipu...ash_HowTo.html
I suppose you can also check the switch itself set at resistance and see if you multimeter goes from infinity to zero. How did you soldier it? I used the resistor points that Cdrskull drew up and I had no problems.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 04-25-2004, 04:06 AM   #8
archimense's Avatar
As it turns out the Lilliput does not respond to the menu button when the it doesn't have a vga signal, or atleast mine doesn't. Once I hooked up the VGA cable it started responding to the menu button. I guess this is what I get for testing things as I go. :P
Thanks for the suggestions everyone.
WTB: Lilliput 7" Touchscreen OR InDash Touchscreen VGA LCD aoLhaTer Classified Archive 4 04-27-2004 12:31 AM
my lilliput into indash conversion samc LCD/Display 4 04-24-2004 10:08 AM
Lilliput indash non motorized housing crash893 Newbie 10 03-31-2004 06:49 PM
My Lilliput conversion CdRsKuLL LCD/Display 1 03-17-2004 09:30 AM
indash housing and lilliput? LudeAtude General Hardware Discussion 2 02-07-2004 05:31 PM
