Old 04-27-2004, 01:34 PM   #1
Help !!, Lilliput In Dash Convert gone wrong
Hi all,
this is my first post here so hope it all makes sense.
got my in dash housing from armen and set about the conversaion, all seemed to go well until i hooked it back up, power on fine, Av 1/2/vga switch changes through the options, on screen no signal and menu all work fine.
But it wont show any pictures , always gives no signals av1, av2 or VGA, i di not cut off the usb ;/ vga wires i simply cut them and re joined them so did not solder any of their points on the board, only solderd on the wires for the front switch and power / av1 /av2 wires.
Chips on the controller are getting warm so they seem to be getting power ok, back light is on and as i say get on screen display so cant figure it out.
any help MUCH MUCH appreciated, if not guess its another Lilliput !!!
Mark Ward
Toyota Celica SR, Lilliput or did have one
Acer Travel Mate laptop using Media Engine.
Info Navigator GPS, Dlink radio and TV tuner.
markie is offline   Reply With Quote
Old 04-27-2004, 01:44 PM   #2
Raw Wave
Laidback's Avatar
The search button is your friend! There's lot's of posts on how easy it is to not connect the ribbon cables correctly etc. etc.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 04-27-2004, 02:02 PM   #3
Jesus Freak
antimatter's Avatar
Laidback is right. It is probably a ribbon cable. Playe with them until you get a picture. Try inserting it all the way to the left side...then the right side.
antimatter is offline   Reply With Quote
Old 04-27-2004, 04:35 PM   #4
Thanks guys,
already tried all the cables, the only two cables are the main feed to the screen and that is fine because of the on screen messages which are generated by the controller so that one is fine, have tried to insert it again and again no change (just in case). Only other is the small one that goes to the touch screen controller and that makes no difference to the video input signals.
checked power and video connections i solderd with a meter and all are definatly getting through, certainly to the next component or connection in the circuit.
Mark Ward
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 03:58 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Need help with dash work, lilliput mount Noble General Hardware Discussion 4 03-22-2004 04:05 PM
temps in trunk vs dash Saurk General Hardware Discussion 1 03-14-2004 10:27 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 10:36 PM
