Display brightness
Property today stated that my Liliput in the car has one miserably brightness... , if I operate the display by means of power pack, the brightness is perfect at home!
I have somewhat experimented and the following to determined:
Original electronics, which is in the case of the display about in order to supply this from the autoelectrical system, makes only 11.9 V available in the no-load operation. First times the display keeps switching on on long right after to that also approx. 1 minute its full brightness. Then it becomes suddenly - subjekitv - more darkly around nearly half. These "feature" I cannot observe, if I operate there the display by means of 220V power pack (the open circuit voltage is also with nearly 18 V!). Thus I measured the tension, if with the autoadapter the brightness breaks down - and actually * the open circuit voltage * has then only more 11.5 V - how much the adapter makes IMHO available then under load points I not, but surely still less... Thus I make now one * direct * adapter - whose tension always places 12.2 to 13 V (also under load) ready. And there see, the brightness achieves its full level and holds!
Regards
Oliver
http://picasso.zoffi.net
