Old 05-02-2004, 05:30 AM   #1
djmickyg's Avatar
will this cable actualy work??
http://cgi.ebay.com.au/ws/eBayISAPI....sPageName=WD2V
ive got a toshiba 1730dtc laptop ..
it says
"Please, check your PC & Video Card manual or manufacturer to make sure that your VGA card has TV-Out function capability to ensure this cable will work for you! "
how would i do that
djmickyg is offline   Reply With Quote
Old 05-02-2004, 05:53 AM   #2
Raw Wave
Rob Withey's Avatar
how would i do that
Find your laptop manual. Read it. If it says it has TV out, you're in luck. If it doesn't, you're out of luck.
From a quick search on the web, I'd say you fall into the latter category.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Earthmate USB to Serial cable New_Compact GPS 22 05-22-2008 02:55 AM
Clifford Cliffnet data cable thenominous General Hardware Discussion 18 10-03-2007 09:40 PM
To extend my 5 wire touchscreen cable or not? e_fractal General Hardware Discussion 1 11-07-2003 05:31 PM
Vga to Svideo cable? si2001 LCD/Display 3 11-01-2003 02:33 PM
Ah! My LCD won't work infrared LCD/Display 12 04-15-2002 11:19 PM
