Old 05-05-2004, 06:57 PM   #1
Goose's Avatar
Goose
Need destroyed Lilliput or just fron chassis
Hello...
I am going to modyfie my center console in my car but I am not good inuff in this and I donæt want to open my lilliput, so I need a destroyed lilliput 7" or just a fron chassis.
Maby some one has it so I can buy it for a few bucks or just get it?
editdamt I was to fast, it should be need not neew )
Goose is offline   Reply With Quote
Old 05-05-2004, 07:05 PM   #2
samc's Avatar
samc
Then how were you planning to put your lilliput into the dash?
Anyhow there has just been 2 lilliput groupbuys and alot of people would be converting to indash I assume so just put up a "WTB: lilliput housing" post.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 05-05-2004, 07:12 PM   #3
Goose's Avatar
Goose
I want to make it like Njay's center console (I am talkin here about 2000 Toyota Celica)
Here are picture of my orginal center console and how I want to mount lilliput.
Old 05-05-2004, 07:50 PM   #4
kiltjim's Avatar
kiltjim is on a distinguished road
You've got PM
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 05-12-2004, 12:35 PM   #5
NJay's Avatar
NJay
You don't need to destroy the lilliput console at all.
What I did when building that console was :-
Removed the pocket cover (its held in by a spring loaded clip)
Covered the lilliput screen with some padding and then use masking tape over the sides and back.
Removed the top bar between the pocket floor and the double din hole.
Hotglued a 1din cage in place at the bottom
Keet offering up the lilliput to the console and kept cutting enough of the pocket, side & surrounds away until the screen sat flush with the surround when placed above the 1 din cage.
Then it was out with the some aluminium mesh to fill in the gaps
Next, I just kept adding car body filler and smoothing in out till the sides all looked as though they were stock shape.
Kept dremelling and adding bodkyfiller till I was happy before primering and then spraying in as close a match metallic paint as I could find (which was actually for Rover's, gunmetal if I recall, NOT Toyota)
Once it was all sprayed up I affixed an angled bracket to the underside of the pocket and attached the lilliput to that.
Finally, put a thin bead of black silicone around the screen.
This way the screen can be removed and sold on at a later date as the silicone is easily removed.
HTH
My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
NJay is offline   Reply With Quote
Old 05-12-2004, 01:16 PM   #6
Goose's Avatar
Goose
Thx Njay.
Iwas thinking about to make it like you are saying, but I think I will try to
do it like Wielke has done it in his 200sx:
Therefor I will buy a housing from kiltjim.
I think It be a nice and clean install, I know that I am "looking me in to" 7" lilliput but whis screen is great.
I will see what I decide to do.
More pictures will come when I am start to modifying me console...
Old 05-12-2004, 02:09 PM   #7
darkhalo's Avatar
darkhalo is on a distinguished road
nice
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
