Old 05-05-2004, 10:30 PM   #1
faiz_23 is on a distinguished road
Question lilli positive or negative
on the lilliput cable, which one is the positive and which in negative, i will be hooking this up tommorow, on the cable, one has stripes and the other is solid, on my power inverter, the strip cable was positive, i am not sure if that is the same on the lilli
faiz_23 is offline   Reply With Quote
Advertisement Sponsored links
Old 05-05-2004, 10:33 PM   #2
samc's Avatar
samc
bingo.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 05-05-2004, 10:46 PM   #3
bingo, as in the stripe one is positive, and the one with the description of the type of cable is negative, so i hookup the stripe one to the yellow cable on the fdd power plug, and the one with the tiny writing to the black on right beside the yellow,
thanks for the wuick reply
Old 05-05-2004, 10:50 PM   #4
samc's Avatar
samc
Another easy way to check is crack open that cheesy $0.01 cent cigarrette lighter plug. Center point is positive, sides are negative.
Old 05-05-2004, 10:53 PM   #5
cool, since i will be using the cable on the egg adapter, am i wiring it righ to the opus, positive to yellow, which will be the center, and the negative, the outer to the black, also do i hack off the egg and jsut use the cable since the egg is a worthless peice of crap regulator
Negative voltages on Sproggy 2.8 way off, need help. rbarr110 Power Supplies 21 09-26-2002 11:05 PM
Negative Voltages: are they bypassable? mbarron Power Supplies 1 09-01-2002 10:30 AM
need negative voltage to power PSU l4tran Power Supplies 2 05-11-2002 10:40 AM
Negative Voltage. Arby Power Supplies 2 10-12-2001 04:35 PM
DC/DC and Negative Voltage JPerfetto General Hardware Discussion 2 11-30-1999 11:43 PM
